10-13-2020, 03:03 AM   #16
As others have said, zooming in that much will show a pixelated view. Unlikely that you will see this in a print at normal viewing distance. If you do find that you want to "up-res" your photos because you are printing really big, there is software that can sometimes help, like Gigapixel AI from Topaz labs. But I think for 1 meter on the long side prints you should be OK.
10-13-2020, 03:22 AM   #17
QuoteOriginally posted by JohnX Quote
OP. Are you sure that you're not just seeing air-borne seeds or similar captured in the photo?
It was snowing when I took this photo
10-13-2020, 11:17 AM   #18
MossyRocks's Avatar
QuoteOriginally posted by StiffLegged Quote
I used to look at raw files at 200 or 400%, until it was pointed out how pointless it was. If it ainít crisp at 100% then it wonít be sharp at larger magnification, so I donít do that anymore.
Generally I agree, but there are times when I will examine an image at more than 100%. However there I am doing so as a qualitative evaluation of a lens likely for astro shooting so I want to see where the lens gets to its best and see what types of chromatic aberrations I am getting and how big they actually are so counting pixels becomes important. After that I don't bother and just take note of where things get acceptable and where they are the best. that isn't something I do every day and once done I likely won't ever view things shot with that lens at more than 100% unless I am working with a heavy crop and trying to get it so it doesn't look too blocky while still giving enough sharpness or working on doing some noise reduction on a very noisy image and trying to not lose fine details in the process.
camera, dslr, f2.8, full frame, full-frame, ii, image quality, k-1, k1, k1 mark ii, pentax k-1, pictures, pixels, pixels on pictures, quality, quality of photos
K1 or K1 mark ii Kevin.mcde Pentax DSLR Discussion 23 05-06-2019 04:46 PM
K1 to K1 Mark II or not II Kingman Pentax K-1 39 03-07-2019 10:09 PM
Pentax-K1, Playback: Is it possible to switch Images if zoomed in? Martin__ Visitors' Center 7 06-04-2016 12:38 PM
I am confused...zoomed out shots outside are not crisp crossover37 Pentax DSLR Discussion 6 03-22-2011 01:31 AM
All times are GMT -7. The time now is 09:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
