Originally posted by Riggomatic Push the AF mode button on the camera (when in live view) and use the e-dial to select different modes. Set the mode to Select, then you can use the rear dial or 4-way buttons to pick your point.
Hope that helps
I've tried that and it moves the focus point when using the viewfinder but not in liveview....
I also have the AF button being used for back button focusing if that makes a difference.
---------- Post added 10-27-20 at 04:24 AM ----------
Originally posted by Durf I've tried that and it moves the focus point when using the viewfinder but not in liveview....
OK, I just figured it out! Thanks
