10-27-2020, 09:48 AM   #1
Sun
Good morning,
I'm trying to do a time laps of Venus and Sun arising from the sea. K-1 suggests me to change setting to get the right exposure when sky light start changing. With the Sun very close it fails and if I follow my shots are white burn. I made some underxposure shots to the Sun but landscape appear darker then. Looks like I have to do double shoot for just one frame to be made in pothoshop later isn't it? Curiously, at that point the sunlight is not very strong, I could watch the Sun without sunglasses, an impressive experience. I bear contact lenses which protect my eyes from UV anyway...
My lens was the FA 15-30 mm, if for the night job is the best I have, it brings some disadvantage for the day: F22 max and no filters. I also have a set of 49 mm filters: UV, CPL (good for water) and ND1000 (never used) for FA 100 mm and FA 50 mm, both Macro. Should I try with 50 mm Macro with filters as a compromise?
PS Can that Sun damage my FA 15-30 mm lens or any other without UV filter?
10-27-2020, 10:22 AM   #2
pschlute's Avatar
QuoteOriginally posted by corvaz Quote
For this kind of shot forget the camera's meter. It won't give you the correct exposure. You will have to practice with manual exposure.
Take a number of images and do a HDR merge in Photoshop. But I would suggest you don't want the landscape to appear too bright.
Lee Filters (and I am sure others) make a filter kit for this lens. It is modelled on the Tamron 15-30, on which the Pentax was based.
I doubt the sun (bright sun) can do any damage to your lens, but if you are not careful it can damage in your camera's sensor, UV or no UV filter. Same goes for your eyes.
10-27-2020, 10:39 AM   #3
photoptimist's Avatar
Nice concept and it's a challenging one to get right because the sun is so much brighter than the landscape.
Do be careful. Although the sun's energy is heavily filtered by the atmosphere at sunrise, the intensity rises rapidly as the sun rises higher.
Yes, the sun can damage both your camera and your eyes even with a UV filter (think about burning ants with a magnifying glass). When focused by a lens, the image of the sun has very dangerous amounts of both visible light and infrared light. (Sunlight is only 10% UV and 40% visible-- fully 50% is IR that can burn). Although wide angle lenses are less likely to create super-hot spots, I have seen internet evidence that an 18mm lens could damage a sensor during time lapse photography during full daylight. Longer focal length lenses can burn holes in the shutter and the mirror box.
10-27-2020, 01:06 PM   #4
I found a Nisi holder but very expensive... ok maybe for the future I've already spent some money.
---------- Post added 10-27-20 at 01:08 PM ----------
Yes, the sun can damage both your camera and your eyes even with a UV filter (think about burning ants with a magnifying glass). When focused by a lens, the image of the sun has very dangerous amounts of both visible light and infrared light. (Sunlight is only 10% UV and 40% -- fully 50% is IR that can burn). Although wide angle lenses are less likely to create super-hot spots, I have seen internet evidence that an 18mm lens could damage a sensor during time lapse photography during full daylight. Longer focal length lenses can burn holes in the shutter and the mirror box.
Thank you sir I'll do.
10-28-2020, 02:33 AM   #5
This morning recording a rising Sun with the FA 50 mm f32 max I got a kind of red spot even I coudn't see it on display. I used also a Hoya UV filter.
10-28-2020, 04:11 PM   #6
pschlute's Avatar
You will do best to upload the picture so we can make a serious suggestion.
But a couple of points....
f32 is not recommended for photography.
When shooting into the sun you are best to avoid filters completely (unless they are ND or GND ) More glass equals more flare
10-29-2020, 03:23 AM   #7
One I made with FA 15-30 mm, the other with flare I made with FA 50 mm Macro f32 plus CPL and ND1000 and that same red spot appeared also recording video using that same 50 mm plus UV filter.
Why f32 is not recommended?
Is CPL good as GND filter?
PS I could see if there was flare on diplay, last time just didn't notice.
10-29-2020, 05:53 AM   #8
pschlute's Avatar
You have lens flare in both pictures, more noticeable in the second picture. One of the hazards of shooting directly into the sun. Again the more filters you use the more the chance of flare.
At slower f-stops (f16 f22 f32) you are going to introduce diffraction into the image. This will make it softer....not as sharp. For landscape photographers wanting a very wide DOF, it is a trade-off they must consider. I am not saying you should not use f32 , but you should be aware of the limitations. For your kind of images here, diffraction will not affect much.
A CPL will darken the image overall, but a GND filter would suit this type of scene better.
10-29-2020, 09:02 AM - 1 Like   #9
Do you mean like that?
Yesterday, after recording, I made some shot and only one was without flare. Even is dark it can be used somehow. I was using 50 mm with UV filter.
Even without a direct Sun, filters should be usefull for any landscape.
10-29-2020, 10:02 AM   #10
pschlute's Avatar
There is no need for a UV filter in landscapes on digital. With the sun in your frame it will only make flare worse
10-29-2020, 11:03 AM   #11
Yes I do agree and I'd like a GND.
10-29-2020, 11:57 AM   #12
pschlute's Avatar
You can easily remove the flare in PP if it is a problem.
damage, dslr, fa, filter, filters, full frame, full-frame, k-1, k1, lens, lenses, light, macro, pentax k-1, shots, sun, uv
rebirth of the sun lplade Monthly Photo Contests 3 12-09-2019 05:57 AM
Pink Sun Bizarr Pentax KP 36 04-11-2019 08:42 PM
Landscape The sun rises and the sun sets. Mallee Boy Post Your Photos! 5 07-22-2013 04:09 PM
Sun and just the Sun vsmouli Post Your Photos! 1 08-26-2009 05:41 PM
Cool pic of shuttle with sun backdrop. larryinlc General Talk 2 05-17-2009 11:30 PM
All times are GMT -7. The time now is 11:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
