12-21-2020, 02:29 AM   #1
Pentax K1 and FA 80-320 mm F-- error
Hi guys,
I bought that lens from an eBay seller, it looks good but I get "F--" blinching error on viewfinder. I can see and zoom even in live mode, but autofocus does not work and I can't shoot in any mode
Shouldn't it work for K1?
12-21-2020, 02:38 AM   #2
MarkJerling's Avatar
Is the aperture ring on the lens set to the 'A' position?
Is the AF-MF camera setting set to AF?
Check and clean the lens contacts, both on the body and the lens, by giving them a rub with a soft cloth.
12-21-2020, 02:44 AM   #3
The most common reason is an aperture ring not set to A. If it is, then there is good chance the lens is defective. That said there is a setting on your body that will allow to take shots nonetheless (Allow Use of Aperture Ring) but autofocus will be out.
12-21-2020, 03:49 AM   #4
Otis Memorial Pentaxian
QuoteOriginally posted by corvaz Quote
"F--" in the status display just means that the camera does not detect a lens that supports aperture control from the camera.* It most often occurs with adapted lenses and original K and M series lenses that lack the required mount contacts. Since your FA series lens does have the required contacts, the usual cause is not having the aperture ring locked in the "A" position so that those contacts are enabled.
* When F-- is displayed, all automated exposure modes default to Av mode with the lens remaining wide open regardless of aperture ring position. Manual modes (M, X, and B) continue to be operational except that metering is limited to stopped down methods using the green button or optical preview lever. P-TTL flash is also not available.
12-21-2020, 03:57 AM - 3 Likes   #5
Thanks you all... Yes there was a ring not set on A now it's working!
12-21-2020, 07:46 AM   #6
Good to know! This information is also on page 109 of the camera manual as part of the documentation for the menu setting to enable the aperture ring.
12-21-2020, 07:47 AM   #7
UncleVanya's Avatar
I am glad to hear that. My own copy some years ago developed these same symptoms but with the ring in the right place. Those lenses are more fragile than they look. Room what I recall there is a small internal plastic bit that can break that disabled mine.
dslr, error, fa 80-320 mm, full frame, full-frame, k-1, k1, k1 and fa, mode, pentax k-1, pentax k1
Nature Isle aux Coudres @ 28 mm, 45 mm and 63 mm FL with DFA 28-105 mm HD and f/16. RICHARD L. Post Your Photos! 4 11-12-2020 09:37 PM
For Sale - Sold: Pentax SMCP-FA 80-320 mm F/4.5.-5.6 with Caps REDUCED rosettaquarrier Sold Items 3 08-07-2019 10:54 AM
SMC F 28-80 and FA 80-320? butangmucat Pentax SLR Lens Discussion 8 02-24-2019 07:53 AM
For Sale - Sold: Brand New FA 31 mm, FA 77 mm, DA* 60-250 mm, DA* 300 mm ppkkcao Sold Items 14 11-02-2014 08:42 PM
All times are GMT -7. The time now is 01:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
