Originally posted by Cee Cee this sounds like normal battery function to me, high use will deplete the battery but it will recover somewhat after some time, determining if you battery function is below normal may be a little difficult to determine, probably the easiest method would be to compare the performance against another battery, it's a good thing to have a second battery
Based on my experience, the word "normal" doesnt come to mind.
However I think that on my third-party backup battery the effect is worse. I would have to test the batteries side by side to arrive to a more reliable conclusion.
My friend uses a k-50 with the same batteries and doesnt suffer from the same problems (at least as much).
