Originally posted by malc77 Hello again,
Thank you again for your replies. Presumably (although I haven't taken my K30 apart yet) the older 'made in Japan aperture block solenoid' has an armature made from low coercivity material such as low carbon (soft) iron, and does not retain its magnetism once the field is removed. Whereas I am presuming the Chinese version does not use a sufficiently low coercivity material armature?
As a clock and watch maker with a workshop, I wonder if it is reasonably possible to make a replacement armature using soft iron etc (eg from an old solenoid or electric bell etc) to replace the Chinese armature? I guess it would be a simple machining job.
Anyway,
Regards,
Malcolm.
Because this was an interesting suggestion I made an experiment with a K-30.
I left the green solenoid and just ex-changed the plunger using the plunger from a white made in Japan solenoid.
Because I have many chinese green solenoids here (from repaired Pentax bodies) I first made the test comparing the holding force against each other
but nothing changed, the holding force of the green solenoid with the plunger of the white one was still too strong.
So anyway I decided to install that modified green solenoid into a K-30 that but leave it open (for quick exchange)
It first worked alright which often is the case if you just manually release the plunger but this method works only very short term.
So I left it just on a shelf and then, partly due to Corona, forgot about it completly and now checked it:
The problem is right there, dark images, the solenoid won't release.
And yet the alloy is different, one can see it and thus the main body which holds the permanent magnet could magnetise differently because it is part of the whole assembly.
But this does not explain problem #1: The holding force which just is too strong.
Anyway, the solenoid of a K70 with late manufacture has a less strong holding force now but it failed.
The reason could well be the magnetism of the alloy but also it being vulnerable against the sudden impact of the plunger onto the main aperture.
I have seen change of surface this main aperture. And yet I see also the different guiding-ability (bearing) of PET against PTFE (Teflon) as one reason, because
PET just does not act that well as a bearing compared to PTFE.
I have seen bearings made out of PTFE which had very strong and long use but last very long.
It could even be that just soldering the pins on the PET body already deformes it slightly while PTFE can withstand much higher temperatures.
One can verify this very well with RCA sockets or RCA connectors. Most of them have PTFE or Teflon (the name DuPont gave it).
The melting-point of PTFE is 326.85 °C (620.33 °F)
The melting-point of PET is 250 °C (482 °F)
That is quite a difference and could play a role
