Originally posted by beno Exactly this, is does the same thing as if it can't confirm focus and refuse to take shot because of this.
Focus works ok in auto and manual mode, it puts the dot in green on viewfinder and green squares in LV.
I'm using AF-S and focus priority, maybe I'll try shot priority next time it happens.
But it is real bug for sure I can even shut down the camera and turn it back on it does not work. Even in a different place or with another battery.
I know you have mentioned that you are having the camera checked out, and you may already know this, but if you are in AF-S mode the focus is going to interpret the first time your first shutter press halfway as your focus on your subject until you let up, and in reference to using focus priority, you may want to try the shutter release-priority setting to avoid missing shot opportunities and having the freedom to release the shutter when you want to. I use AF-C (continuous AF mode) and shutter release priority. This assures me that I constantly have the decision on whether to shoot or not. I have my beep and light focus signals to tell me when AF is in focus. I also use Spot mode (center point) as my AF focus area mode, with the possible exception of when I am shooting landscape in some instances where I may switch to multi-point AF.
If the problem has any pertinence to power consumption, which it may not be, I would recommend the use of Pentax batteries exclusively for shooting.
Good luck. I hope things work out for your camera and your shooting.
