Originally posted by Oxygenum RawTherapee 5.8 WB CTE problem?
White balance is sort of a sticky subject. As noted above, the DNG data has no notion of white balance. That said, the makernotes section of the EXIF metadata does include the camera's white balance settings as a "hint" to software such as Lightroom or RawTherapee.* The tag name used by ExifTool is WhitePoint and the value is four integer numbers, representing factors to be applied to each of the four color channels (R, G
1, G
2, B) for processing. The numbers for IMGP6092.DNG are:
21024 8192 8192 12640
Strangely enough, that is all there is. White balance is a surprisingly course adjustment. Looking at IMGP6092.JPG, the same four numbers are present as documentation of the camera's setting, that actual factors having already been applied.** IMGP6092neutralWBRT.JPG has no manufacturer's metadata, being that it was made by RawTherapee.
I don't know what the "neutral" setting is, but I did notice something interesting in comparing the DCU JPEG with the RT JPEG. The DCU version has sRGB as declared color space and also has that standard profile embedded in the file. The RT version on the other hand declares RTv4_sRGB and embedded a quite different profile matrix in that file. Depending on the display software/device, that in itself might be enough to account for the difference in colors.
Beyond that, the RT JPEG appears to have been processed darker by quite a bit with less contrast.
Addendum: I processed in Lightroom using default import and Adobe Standard and got results almost identical to that from DCU. Lightroom evaluated the color temperature at 6900.
* Lightroom will also apply a tint value, but that is not pulled from the EXIF.
** In the case where a RAW converter is not able to pull WB factors from the EXIF, it uses a standard set of values for 5200K and a neutral gray subject.
