Originally posted by syyrmb I‘d say the building is at least 500 meters away from me.
The distant one, yes - but the slightly out-of-focus cropped area you first posted is only a few metres away, yes? I'm making that assumption given the 50mm focal length...
Originally posted by syyrmb I just tried to disable lens correction in RT, no effect, still the same, and I believe the distortion is in the image for my experiment with DCU below.
I uploaded my file to there:
IMGP1415.zip - File.re temporary file sharing
(please only use it for studying purposes)
After hearing your suggestion, I tried DCU and disabled motion correction, image shows motion artifact and blurs, which shows that the distortion is inherited in the image.
I've had a look at each of the images in the pixel shift "deck"...
Certainly, there was some wind that day, as there's a piece of webbing tied to one of the upright metal railing posts (lower left quarter of the scene) and you can see it changes position considerably between frames. I also wonder if there may have been a chimney or vent below and/or to the left of the scene, such that air of variable temperature (and perhaps humidity) could have blown across the scene by the breeze. Lastly, is it possible that the surface on which your tripod was standing could have distorted with your own movements?
Although I've no firm conclusions, I'm thinking this may be the result of camera movement (for one or more reasons) combined with electronic shutter... but wouldn't rule out thermals carried by the breeze as either the sole reason, or a contributing factor.
