02-04-2021, 08:15 AM   #1
Sand under the shutter/focus button.
Hi all,
I seem to have some grit/sand in my shutter/focus button. It seems to be stuck down, so as soon as you turn it on it takes pictures, i have played around with it with no luck. The camera is a K-70, but I'm guessing the part is similar on most Pentax DSLRs. Do they just pop off if I get a nail underneath the plastic on/off label surround? I dont want to force anything, but I'm sure if I could get access to the actual button it it would easily free up.
Any help would be much appreciated!
Conor
02-04-2021, 12:49 PM   #2
MarkJerling's Avatar
Hi Conor,
If the camera is still under warranty, I'd suggest sending it in for repair. The button does not just "pop off" so attempting to pry it up won't work. To gain access to the back of the button assembly, the entire top plate needs to be removed and that's quite a bit of work.
Regards,
Mark
02-04-2021, 02:09 PM   #3
SharkyCA's Avatar
QuoteOriginally posted by Conor Rowlands Quote
Hi all,
Conor
If you are feeling adventurous here is a write up by Photogem that may help on disassembly of the k70.
Tutorial/Repair Pentax K-70 with aperture-problem: Exchange solenoid - PentaxForums.com
02-10-2021, 05:05 AM   #4
Hi all,
Indeed, most ON/OFF / Release-buttons are similar on most Pentax DSLRs.
Even if there is warranty, they might deny it because getting a grain of sand there could be a reason to do so, depending how urgent they need money.
But it is easy to fix and you follow the instructions shown HERE
How to disassemble the ON-OFF Switch and Shutter-Release-Button you can see HERE
I would advice you as you anyway have the camera open, buy of find a white Japan-solenoid and replace that as well.
But that's your choice of course, but I would most certainly do it if it were my K-70 because one has piece of mind and the K-70 fires faster
particular when doing serials!
If the switch is different, take photos and show us of course!
Every step is useful for others.
It is important for those who help to have feedback how the suggestions worked or what the outcome was!
button, damage, focus, pentax service, repair, sand, service, shutter, warranty
Pentax 67 Wind lever and shutter shutter button L Stymiest Pentax Medium Format 4 01-23-2020 01:27 AM
Disable green button for back-button focus? Igor123 Pentax K-1 & K-1 II 7 06-03-2019 08:01 PM
Shutter not opening, shutter button stuck and unresponsive ( Pentax ME) pentytaxy Troubleshooting and Beginner Help 3 04-16-2016 12:54 AM
645Z Gets Covered in Sand and Run Under a Shower interested_observer Pentax Medium Format 3 07-02-2014 07:16 PM
Travel 700 Miles, 2 Wheels, and Lots of Sand -- Great Sand Dunes NP Colorado CJ Post Your Photos! 11 07-09-2013 05:33 PM
All times are GMT -7. The time now is 10:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
