Originally posted by Wildturkey Ok.. Had a K1000 went to D110 then saved my penny's an bought a K-70. Love this camera no really. Then reading I find this article on this Pentax Aperture Block Failure. Great is this in the newer models I bought this one Oct,18 .2018 new. So far great is there a count or should I make sure the D110 close .
I guess you mean the Pentax K110D!
This is a good donor if ever ABF would occur in your K-70 because it has 2 of the precious Japan-Solenoids.
If ever this would happen, you could swap solenoids:
You just remove the Japan-Solenoid which opens the pop-up flash in your K110D.
Then you disassemble the K70, get the green China-solenoid out, which you used for the pop-up-flash of your K110D
because it won't get stuck there ever and then you insert the Japansolenoid from your K110D into the K70 for aperture control.
So just in the rare case (I guess 1-2% likelyhood) your K70 would develop ABF you are well prepared.
If you can't do it yourself, find somebody here in the forum, there are many who have done it.
But don't worry, enjoy the great K70 which is a masterpiece.
But one good advice to minimize ABF: In most cases it occurs when the camera is not used over a longer period.
I just repaired today a NOS K30 (it came to me with a shuttercount of about 35 but just because the owner tried to find out what was wrong, since its make in 2012 it was never used!) When unpacked: ABF!
So using your K70 (which is anyway what it was made for) is a good idea.
