07-14-2021, 01:23 PM   #1
AF.C in video mode
I have been playing with video and found that I am not able to select AF.C in video mode, it is disabled in the menu. This is with the kit 18-55mm lens. However if I put on the 55-300mm PLM zoom it does allow AF.C
The manual says that video af.c only works with certain lens but then does not appear to state what the criteria are.
I want to use a wider lens around of 18mm, does anyone know what the criteria is to make it work?
07-14-2021, 01:35 PM   #2
Actually, with that wide a lens, focusing may not be a big issue. If you use a moderate f-stop (say f8), you should be able to set the lens just short of infinity (manual focus) and leave it there. Unless you're trying to focus up close, an 18mm lens at f8 will be pretty sharp from a few feet out to infinity. A problem you'd encounter with AF is that it will have a hard time working with an 18mm lens and may actually hunt, thus causing issues. Manual focusing overcomes that as long as you have a good depth of field which 18mm can deliver. Of course, if you want to use a longer focal length, then focusing can become a necessity. I'm not sure what the AF.C limitations are for motion photography with the K-70.
07-14-2021, 01:42 PM   #3
It's a K-70.
The issue I have is that it's me I want to focus on so I cannot be in front and behind the camera at the same time. I tend to end up with soft focus all the time
07-14-2021, 01:55 PM   #4
One way to accomplish that is to use a separate off-camera monitor which you can see. That would allow you to focus while being the subject. You'd need a monitor of size and sharpness to meet the task.
07-14-2021, 02:41 PM   #5
swanlefitte's Avatar
Your experience suggests only kaf4 lenses work. Just a guess.
There are only a few at present. The new top of the line lenses are all kaf4. The announced da*16-50 will have it but way more $$$ than a kit lens.
07-14-2021, 02:44 PM   #6
The 55-300 plm is the only lens that works with AFC. It's possible they might update the firmware when the 16-50 comes out but who knows.
07-14-2021, 06:02 PM   #7
Otis Memorial Pentaxian
clackers's Avatar
QuoteOriginally posted by mlines Quote
The brand new DA*16-50 will be the second PLM lens, Mlines!
07-14-2021, 06:06 PM   #8
clackers's Avatar
It's a K-70.
You prefocus, Mlines. You don't want focus to change repeatedly during a scene, anyway, it's awkward, like seeing a camera bob up and down handheld. You see amateur Youtubers where the focus racks in and out until it's happy!
Put anything on the chair beforehand, or if it's a standing scene, a tripod or similar.
Have you ever seen how a TV show or movie is made? There is tape on the floor for where the actors have to end up in a scene to be in focus. Professional production is manual focus, manual aperture. Nothing's left to chance.
af.c, criteria, k-70, k70, lens, mode, pentax k-70, video
Pentax K1 wifi and image sync in Video mode paulpixeld Digital Processing, Software, and Printing 3 09-28-2020 12:56 PM
Video Mode - Still changes Aperture in AV mode Snakeisthestuff Pentax K-1 & K-1 II 4 03-08-2018 02:43 AM
K-1 AF in video mode i83N Pentax K-1 & K-1 II 18 04-01-2016 04:01 AM
Dave.R says no AF in video mode Mike.P® Pentax News and Rumors 20 09-22-2010 05:53 AM
Will using the video-out when in video mode help conserve battery? greenless Pentax DSLR Discussion 2 12-14-2009 02:49 PM
All times are GMT -7. The time now is 08:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
