Hello! After almost 2 years of using my k70 with my wide manual lens only (shutter block failure), I'd like to finally repair my camera so I could use my other lenses. I tried to check at a repair shop but they denied since they don't have the piece.
Then, I started to look at tutorials with the goal to do it myself, it seems like there is a white and green version of the solenoid. In the tutorials the green one is always replaced by a white one (, however when I look online, I only see green solenoids for sale. (I mean, I saw a white white once, for 50€...)
Does buying the white version over the green solenoid matters or not? Where to get one for a reasonable price?
Thanks.
