Originally posted by photogem what do you mean with variable (max) aperture?
I don't understand the meaning of max.
A zoom has variable focal length, and aperture changes with most zooms when changing the focal length,
so that is clear.
But what about (max)?
Possibly again a question of language!
Well, using Av mode with an afflicted K30/50/70 etc. means that the camera meters with the lens wide open, and
you have to perform the calculation for the exposure at the set aperture - and that means that you need to know the wide-open (i.e.
max) aperture of the lens, because the exposure at set aperture is calculated
relative to the wide-open aperture.
Since many (most) zooms have a variable wide-open aperture, you're never certain what the wide-open f-number is. So you're stuffed, and you probably just resort to using the green button and M mode...
---------- Post added 5th Aug 2022 at 09:06 PM ----------
Originally posted by reh321 Your answer is very confusing. The simple fact is that a camera body, like my K30, is usable with a aperture-ring equipped lens. The aperture set may require a slower shutter speed and/or higher ISO setting than the user would prefer, but that has always been the case. The only difference is that the body cannot set the aperture - back to the old days before ‘KA’ lenses.
If your K-30 has a good solenoid, then if you operate in Av mode with a lens whose aperture ring is set to a value (i.e. not "A"), the camera will refuse to stop down, and will take the shot with the lens at wide-open - so, regardless of the aperture set by the ring. You'll get a correctly exposed photo, but always with a wide-open lens.
But if you try that with a K-30 that has a failed solenoid, the camera will stop down in Av mode - but will still expose as if the lens was wide-open. That's why you need to compensate (by the number of stops relative to wide-open) if you want correct exposure.
Does your K-30 have a failed solenoid?
