Unfortunately the "Astrophoto" mode does tend to dim the LiveView display, though the final results are worth the effort if you're working straight to JPG.
I've taken to setting up, framing and focussing without Astrophoto enabled, at a very high ISO sensitivity to maximise the display detail, then switching to Astrophoto at the last minute for the final exposure.
Working with a wide-aperture lens also helps a great deal.
Old-school manual-focus prime lenses of f/2 or f/2.8 or thereabouts can be found quite cheaply and can put a lot more light into the camera for setup, even if they are stopped down for the final exposure.
Good luck
