Originally posted by AfterPentax Mark II But beware: the solenoids were obtained from several manufacturers so it depends on the batch if you have the danger of being confronted with the solenoid problem.
No, you somehow got this wrong:
The solenoid in all Pentax DSLR was manufactured by Shinmei Japan, but since quite a time they moved manufacture to China, tested it in the flash circuit (solenoid-driven popup-flash) in the K100D, K200D up to the K-r.
Because it worked there without any problem from the K30 onwards it was used for aperture control as well.
But aperture control is more complex and there it started to fail.
So we have ALWAYS from Shinmei three variants:
1. as used in the flash-circuit from the K100D and then aperture-control in K30/50/500 up to Dec. 2015
2. modified with a smaller magnet from 12/2015 in the K50/K-S1, K-S2 and early K-70 (up to end of 2020)
3. more modified with again a smaller magnet from 1/2021 onwards
The exakt date when version 2 and 3 changed is unknown.
Although it was often said that the old DSLR solenoid still made in Japan was made by ALPS and Matsushita this isn't quite correct,
Shinmei sold solenoids to ALPS and Matsushita.
Shinmei also produced solenoids for CD/DVD-ROM drives/burners, which were more simple and have a much much higher holding force
(endless quantities offered on ebay from China, Hongkong and others)
and there is a blue version which is 15ohms only and even worse.
A lot of "jumb on the bandwaggon"- selfmade specialists which try to fool Pentax owners into buying cheap and wrong.
