Originally posted by ColinK70 would someone be able to tell me how I can set a base shutter speed on my K70 so it wont drop below this, I have this in mind for wildlife work. Currently using U1 as a custom user mode set to manually selecting the aperture and shutter speed with the camera automatically adjusting the ISO
This is the same as TAv mode on your mode dial. Some manufacturers allow you to set an AUTO ISO in Manual mode, Pentax instead uses TAv mode. They are both identical modes.
Your problem is that your camera does not remember the shutter speed last used when it wakes/turns on. If you use TAv mode it will remember your last set shutter speed/aperture on wakeup/turn on
The reason why it wont do this in USER modes is because the USER mode remembers things as they were when the mode was last saved. So you can in your USER mode set for example 1/500s and f5.6....then save the mode. Now it will always default to those settings on wakeup/turn on.
