02-23-2024, 02:12 PM   #1
Shutter count
Hi everyone,
I'm looking for used K-70 to buy and wonder how important the shutter count is. Is there any reason to avoid cameras with shutter count above a certain value?
Grateful your advice.
02-23-2024, 02:51 PM   #2
Custom User Title
FozzFoster's Avatar
Some camera within the Pentax lineup have shutter actuation count life span estimations.
However, these entry-level cameras have no official estimation. For many, it's generally considered to be 50,000 actuations.
Check Camera Shutter Count and Manufacture Date
02-23-2024, 03:40 PM   #3
IIRC with the K70 the more important issue is made 2021 or later because of ABF issues with earlier dates
02-24-2024, 03:01 AM   #4
QuoteOriginally posted by Joetitch Quote
I'm a beginner in digital photography. What does IIRC and ABF mean and what are the potential effects?
02-24-2024, 03:19 AM - 2 Likes   #5
pschlute's Avatar
QuoteOriginally posted by gengblom Quote
IIRC is a "newspeak" term.....short for "if I remember correctly"
ABF is a camera term and means aperture block failure, which affected early models of the K-70, which is why the member is suggesting you go for a later production run model.
02-24-2024, 05:43 PM   #6
I usually hear it as "If I recall correctly" - but same diff
02-24-2024, 09:07 PM   #7
If you purchase a K-70 made before Jan 2021 it has a part built inside (solenoid) which can go bad, see:
A LITTLE BIT OF HISTORY: Development of the solenoid in Pentax cameras - PentaxForums.com
From Jan 2021 onwards Ricoh used the 3.rd generation solenoid.
The solenoid actuates the aperture control, ABF is the failure of this mechanism because the solenoid remains stuck.
If you are good in DIY, then it is worth it to buy one with ABF, because they are cheap to have, then you repair it:
Tutorial/Repair Pentax K-70 with aperture-problem: Exchange solenoid - PentaxForums.com
The K-70 has an estimated shuttercount of 100.000, but also important is to know how the camera was treated.
100.000 is quite high, but the higher-range Pentax bodies reach even higher, my K-3 has 160.000 and works well.
I know of somebody whose K-30 has 65.000 and it is fine.
But ABF can happen to an almost unused Pentax with solenoid.
The higher-range Pentax bodies use a stepper-motor instead: K7/5/3/1/KP
A might good Pentax was also the K-S2 (but with the same danger of ABF)
count, k-70, k70, kf, pentax k-70, pentax kf, shutter, shutter count limit
Should I push my shutter speed or count on LR's ability to give me 2 shutter stops ba lazarustx Troubleshooting and Beginner Help 16 04-13-2020 08:09 PM
Survey with shutter count and aperture block or shutter failure. macman24054 Pentax K-30 & K-50 256 12-30-2016 11:47 PM
Shutter count set to zero after shutter unit replaced r4heim Pentax Medium Format 7 01-24-2014 07:58 AM
Does Shutter Count, Count? CertEdFriday Pentax DSLR Discussion 20 11-27-2008 04:27 AM
All times are GMT -7. The time now is 06:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
