View Poll Results: Which body whould You choose?
K-70 8557.43%
K-3 6342.57%
Voters: 148. You may not vote on this poll
06-12-2016, 04:55 AM   #31
QuoteOriginally posted by niceshot Quote
yup dreaded aperture diaphragm block failure, it is such a lovely thing
Right.....its been Haunting me ! The Camera is going to come with the longest warranty I can find , PLUS drops and Spills , and just about anything else that will replace it quickly in the event it happens again.
In Spite of that......ORDERED Last Night !
06-12-2016, 05:02 AM - 1 Like   #32
QuoteOriginally posted by Dlanor Sekao Quote
Pentax in lieu of this problem ought to offer a three yr warrantee, after all it is not the consumers fault this aperture diaphragm block failure
06-12-2016, 05:07 AM   #33
I Got 3 Years warranty, and also drops and spills through New Leaf. Think I'm covered pretty good. Its a major issue to me because I had BOTH my K30's fail.....one at like 50K and the other about 7K both out of warranty.....nether was repaired through Precision.
DAMN........I Keep Calling it the K7......sorry.
06-12-2016, 05:31 AM   #34
Who is New Leaf?
06-12-2016, 07:14 AM   #35
Who is New Leaf?
Here......they go all the way to 5 Years.........
New Leaf 3 Year Extended Warranty, Cameras under $1000 DIG3U1K#!......
06-12-2016, 07:27 AM   #36
It doesn't, appear to be around all that long,hopefully you wont need it
---------- Post added 06-12-16 at 10:30 AM ----------
Concerns about some of the extended warranties (Leaf from Adorama): Sony Alpha Full Frame E-mount Talk Forum: Digital Photography Review read this
06-12-2016, 10:31 AM   #37
... I had BOTH my K30's fail.....one at like 50K and the other about 7K both out of warranty....
I could live with that. I guess I truly am a low volume photographer. I had two Canon Rebels die in an eight year period, with a total count of under 5K. I take maybe 500 pictures a year, and I hardly ever use burst mode.
06-12-2016, 10:39 AM   #38
no composition adjustment on K-70 ??
In your case I would recommend the K-70, since it essentially today's version of the K-x.
Alternatively, you could look at the K-S2 as it's basically a K-70 without the 24 megapixel sensor (20Mp instead) and hybrid video AF. In almost all other key aspects, the two are identical. This could allow you to invest the difference in price toward a prime lens or two. Also, the K-70 won't be available until August, if that's a factor.
Since features like the articulating screen and Wi-Fi seem to be important to you, I'd stick to those two models.
That said, the K-3 has the following advantages, as a higher "flagship" model:
  • All-metal construction (vs plastic on the outside)
  • More durable shutter (up to 200k actuations)
  • Quieter shutter
  • Silent DR II dust removal (vs. audible DR)
  • Wireless flash control, composition adjustment
  • Higher burst framerate (8.3 FPS) and larger buffer
  • More external buttons, certain functions easier to access
Just something to keep in mind.
In terms of image quality, the K-3 and K-70 are going to be virtually identical, whereas the K-S2 is at a slight disadvantage due to the lower resolution and 12-bit RAW. All 3 are a considerable upgrade over the K-x, however.
Most likely, yes. But I'm sure they fixed the issue that caused so many failures.
Let's not jump to conclusions until they actually release the updates. Perhaps support for the K-3 will be included!
In any case, it's not that big of a deal because video-optimized lenses really only make sense on video-optimized bodies. Future lenses will almost certainly stick to KAF3 unless they're designed for video.
You're saying the K-70 wont have composition adjustment, but the K-50 had it. You're sure K-70 wont be having it??
06-12-2016, 11:24 AM   #39
QuoteOriginally posted by reh321 Quote
you could live with that, well hooray for you
06-12-2016, 11:39 AM   #40
I'm more concerned about the DROPS than I am the Spills........regular old Rain and Splashes don't concern me....Its the Pentax Advantage !
---------- Post added 06-13-16 at 02:42 AM ----------
Both Dead and under 5K total ?......That's Horrible !!!
Now we know for sure why You switched to Pentax !
06-12-2016, 02:05 PM - 1 Like   #41
QuoteOriginally posted by anu l Quote
According to the manual and all published specs, the K-70 doesn't have it. It's a feature reserved for flagship models, similar to wireless flash control.
06-13-2016, 12:51 AM   #42
Looking at all the comments above, I think it will be better choice to get K-70, if only the Image Quality is at least the same as K-3.
One thing that is still on my mind, is the AF speed. Is the AF in K-3/K-3 II a lot faster and better than the one in K-70 (I guess K-70 is same module as in K-S2)? It might make a huge difference when taking photos of wildlife and children or am I wrong?
06-13-2016, 01:01 AM   #43
Nuno Almeida's Avatar
Personally I would go for better focus all day long, don't need all that many points, speed and precision... A better flash would be a welcome addition has well, K70 brings none of those things
06-13-2016, 07:40 AM   #44
QuoteOriginally posted by Nuno Almeida Quote
Why are you so certain that AF has not improved in speed and/or precision??
{I believe that is the primary purpose for the new 55-300mm lens}
06-13-2016, 03:53 PM   #45
The purpose of the changes to the af system and the 55-300, by what I know are just for LV, or trough sensor, which I don't care, the Af system remains the same old 11 sensors 9 cross type, has far has I know
af, cameras, children, firmware, ii, k-3, k-3ii, k-70, k70, leaf, lens, lenses, macro, nature, pentax, pentax k-70, ricoh, screen, vs, warranty
Wanted - Acquired: KatzEye Focus Screen for K-3 (K-3, K-5, K-5II, K-7, K-30, K-50, K-500), New or LN fwcetus Sold Items 15 05-07-2016 08:01 PM
Japanese blogger tests K-3 II AF.C performance against K-3: Measurable improvement bwDraco Pentax K-3 17 05-01-2016 10:04 AM
K-3 or K-3 II pentaphil Pentax DSLR Discussion 33 01-27-2016 06:21 PM
K-3 vs K-3 II Shake Reduction mee Pentax K-3 11 12-02-2015 04:53 PM
K-3 or K-3 II zvon Pentax K-3 23 09-04-2015 11:06 AM
All times are GMT -7. The time now is 09:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
