Show Printable Version 8 Likes Search this Thread
11-28-2016, 09:56 PM   #16
SpecialK's Avatar
QuoteOriginally posted by pentax360 Quote
The K-70 has a max ISO of 102400.
I'm sure at the highest setting it's really grainy and not that useful.
What's the highest ISO on the K-70, that still takes good looking photos?
What is "good"?
Seriously, it depends what effect you want, shootings conditions, the subject, and what you or your client can live with.
Documenting cars on a freeway might be OK at 102400K. Portraits, probably not.
11-29-2016, 11:36 AM   #17
Pretty high actually. 6400, 12800, and even 25600 should be fine in a pinch.
I wonder what the analog max ISO of the K-70 is. I remember someone had posted a set of graphs (PF or DPR, not sure) comparing the ISO performance or amplification of K-1 & D810.
If I remember correctly, the pattern changed after ISO1600, which was suggested as a limit for analog amplification & after that it was all digital. Now DPR said in its review that at ISO3200 and above RAW of K-70 seems to be "baked" by some processing. It could be the same case as that of K-1 & D810.
Would like to get some clarity about this - repercussions of analog and digital amplification (If, at all that's the case), and it's effects on RAW and post-processing.
01-27-2017, 05:34 PM   #18
this thread needs photos
01-27-2017, 09:09 PM - 2 Likes   #19
SeaRefractor's Avatar
[IMG][/IMG]
It's compressed from uploading it into my pentaxforums album, but here's an example that I captured at ISO 10000
01-27-2017, 09:56 PM   #20
amoringello's Avatar
You have to decide for yourself what is or is not good. And that might change on purpose.
I have shot ISO 20,000 for low light events and found image acceptable.
Other times, I find ISO 200 too noisy.
Play with it and see.
01-28-2017, 03:57 AM   #21
I am blown away by my 3200 and 6400 pictures. No other camera of mine has ever had such decent pictures at from those big numbers. Sure, above 25,600 you only get internet quality snapshots, but my other cameras, my older ones, only made questionable snapshots at their higher ISOs. I bet the KP follows the same logic and caveats.
01-28-2017, 09:14 PM   #22
KDD
Depend on lenses!
02-10-2017, 08:47 AM   #23
It deppends. One picture will be ok at iso 12 800 and other time will be to noisy. If i use auto iso i set it to 100-6400 outdoor. Anyway most indoors shoot looking good even at iso 12800. I also have few outdoors photos in 12800 im happy with.
iso, k-70, k70, pentax k-70
When camera is in "AF Active Area Select" how to use ISO, Flash, WB, timer buttons? Newtophotos Pentax DSLR Discussion 5 10-12-2015 06:23 AM
K3 "optimum" ISO? IlluminataPhoto Pentax DSLR Discussion 15 05-05-2015 04:09 PM
"Click" in between "C" and "MF" mode on focus selector? K-50 maxwolfie Pentax K-30 & K-50 3 01-29-2015 04:19 AM
Optical differences between Pentax "K", "M", and "A" lenses 6BQ5 Pentax SLR Lens Discussion 31 01-10-2014 01:02 PM
Don't say Pentax "Q" in French ... "Q" = "cul" = "A--" Jean Poitiers Pentax Q 52 11-10-2013 06:25 AM
All times are GMT -7. The time now is 09:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
