Originally posted by yoko666 Well, what do you say about it... i've shot this few days ago via VF. As you can see the focus is only in the middle but the rest is out of focus like only the center is focused (used 11AF). So what to do in this case? Shall i go to Fine adjustment of AF?
Thanx UncleVanya my english is not great, i've setup my diopter to the best position (as you can see in a picture). I really don't know what else to do. I will try with FineAF but i am sceptical about the result. Looks like the lens isn't compatible with K-70
Here's what we need:
1) JPG or RAW from K-70 showing the problem.
2) Same exact scene from K-30 showing no problem using the same exact settings.
3) Same as above for 18-55 from each camera showing no problem. Please use the same exact settings/location/subject etc. If the problem only occurs at > 55mm then that will have to be different but be sure to detail that.
Make sure to keep the EXIF intact and not to process the files.
BTW - the shot above is pretty nice as is.
I do think the issue may be the lens performance being more visibly less crisp than the 18-55 simply because of the higher density of pixels. Even when shooting JPGs at 14mp you are downsampling from 24mp and the sharpness may not be restored depending on the way it downsamples. The larger pixel sites on the older 16mp sensor are more forgiving.
