04-29-2017, 06:39 PM   #1
Slowest shutter speed for Pixel S Res handheld
What is the slowest shutter speed you would use with Pixel Shift Resolution mode handheld and with Shake reduction on? Is it a good idea to shoot in PSR mode handheld at all?
04-29-2017, 07:07 PM - 2 Likes   #2
Just don't bother to shoot pixel shift hand held.
Pixel shift is based on tiny movements of the sensor, literally one pixel in different directions to improve color data. There is no way that this has any benefit unless you are steady on a tripod. Just shoot a single frame and process it and it will be fine and save pixel shift for relatively still days combined with a tripod.
04-29-2017, 07:09 PM   #3
QuoteOriginally posted by Tigs Quote
You should never use it hand held. Your images will be worse than without PSR (unless you extract a single frame).
04-29-2017, 10:45 PM   #4
Its a myth to be able to shoot PS handheld.
Any claim that it can be done is because the user has been using a software that does not tell him/her that the layering in PS did not work due to movement (of which a pixel worth of movement will be enough for PS to not use the other frames).
So just use a tripod.
04-29-2017, 11:03 PM   #5
I've had a play with this in order to see what difference it makes and from my observations, pixel shift doesnt do anything positive when handheld, shake reduction doesn't do anything positive when on a tripod.
I don't know what the compatibility of pixel shift and shake reduction is, but I can't see how they wouldn't work against each other.
04-30-2017, 02:38 AM   #6
pschlute's Avatar
Pixel shift disables shake reduction automatically.
04-30-2017, 02:52 AM   #7
That makes sense
04-30-2017, 02:59 AM   #8
This is very descriptive thus helpful answer, thank you.
04-30-2017, 05:32 AM - 1 Like   #9
For pixel shift, I always use my heaviest tripod (a surveyors tripod actually). The travelling tripods or even my fairly hefty Gitzo Studex doesn't quite cut it. I was frankly amazed at what a difference the choice of tripod made in producing sharp architectural images. For landscapes using the Motion Pixel shift, its seems the type of tripod used is less important.
k-70, k70, mode, pentax k-70, pixel, pixel s res, shutter
Abstract Des Res Kerrowdown Post Your Photos! 2 07-19-2016 09:15 AM
MX shutter sticking/locking over 1/60 shutter speed NitroDC Pentax Film SLR Discussion 4 01-10-2016 03:53 PM
Lightroom configuration for higher res displays Riverlady Digital Processing, Software, and Printing 4 08-10-2015 05:58 AM
Slowest Shutter Speed for People/Portraits? MadMathMind Photographic Technique 15 04-30-2015 06:06 AM
What's the slowest Shutter Speed you use for handheld shots? mojoe_24 Troubleshooting and Beginner Help 32 02-11-2011 11:43 AM
All times are GMT -7. The time now is 09:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
