08-09-2017, 02:11 AM   #1
Setting up Bracketing in U1, U2 and U3 on a K-70
I have a k-70, it's still rather new to me.
I'm traveling to view the total eclipse on Aug. 21.
Here's what I'd like to do. I'd like to program the shots I'm going to take during partial eclipse in the U1 section. I want to bracket those shots, and I need help understanding how to set up bracketing. The owner's manual is pretty sparse. I'm going to be locking the mirror and using a cable switch to shoot.
In the U2 section, I'd like to set up my shots during totality, so assuming the programming and bracketing method is similar to U1, I should be able to figure that out if somebody can offer a step-by-step on the process.
Thank you for your help.
08-09-2017, 06:40 PM   #2
Was thinking the same thing, but I was not able to set up my custom user settings. Not sure you can you set up with bracketing with EV stops in the custom settings? Will bracket 5 shots with 2EV stops is what I will be doing for the eclipse.
Hope this help's
Brian
08-10-2017, 08:50 AM   #3
You just need to select the correct drive mode from the drive mode menu, then save those settings in the user mode via the main menu. Is that what you already tried doing?
08-10-2017, 11:33 AM   #4
Otis Memorial Pentaxian
Questions...
  • Are you able to set up and use the desired bracketing outside the custom U1 and U2 modes?
  • What exposure mode, ISO, and bracket settings are you wanting to use?
  • How is this not working for you?
There are a couple of "gotchas" in the bracket implementation, though the basic setup is straightforward...
  1. Select +/- as the drive mode
  2. Ignore the options for remote or self-timer
  3. Use the front e-dial to select the number of exposures for the bracket
  4. Use the rear e-dial to select how many stops for each step
  5. Press OK
The default settings are to do the bracket as n-number of presses of the shutter release button. The rear LCD should show the number for the next step in the bracket set.
You also have the option in the C2 menu of changing the bracket order (not recommended) and whether to do the full bracket set in a single press.
NOTE: Exposure bracketing and timed interval exposures are not possible using the built-in intervalometer. A third-party remote with intervalometer may be appropriate if that is your use case.
08-10-2017, 06:36 PM   #5
Yes, I was able to use bracketing outside of U1 and U2 modes, and I was able to use mirror lock when in U1 and U2 modes, but I have been unable to use them together in U1 and U2. I'm using a remote (cord) to release the shutter on mirror lock pictures. However, I can't figure out how to program mirror lock AND bracketing in U1 and U2 and be able to use a handheld switch to take the mirror lock pictures.
In U1 (partial eclipse) F10, ISO 100 and SS of 160 to 200, or something in-between.
It's maddening. I've been trying to figure this out off and on for a couple of days. The basic question remains: Can I bracket photos using mirror lock in the U1, U2 and U3 modes, using a shutter release cord.
I very much thank you for your help to date. Everyone.
08-10-2017, 07:55 PM   #6
QuoteOriginally posted by Roger Dier Quote
Thank you for the clarification.
I'm sorry that this is maddening and the basic answer is that you cannot do mirror lock-up and bracketing at the same time. They are mutually exclusive* in both normal use and when saved to a User mode. This is true for both the regular shutter button and for a wired remote release. One can only save a setup that is possible in regular shooting.
* This is the general case for drive modes. Only one may drive mode be active at a time.
08-11-2017, 04:36 AM   #7
Thanks Steve
Thank you Stevebrot for ending a three-day search for a solution that is not possible.
It looks as if I'll have to settle for mirror-lock shooting during the solar eclipse; it's the best bet to get the best pictures.
Many thanks to you and others for your/their expertise.
bracketing, camera, k-70, k70, pentax help, pentax k-70, photography, section, shots, solar eclipse, troubleshooting, u1, u1 and u2, u2
what is your U1 U2 U3 settings on your camera ? redcat Pentax DSLR Discussion 71 02-06-2022 02:01 AM
U1 and U2 with different Focus modes? BruceBanner Troubleshooting and Beginner Help 2 12-10-2015 03:29 PM
U1, u2, u3 mocker Pentax K-3 & K-3 II 6 04-17-2014 12:06 PM
U1 and U2 forget raw setting nigeldodd Pentax K-30 & K-50 2 06-18-2013 09:22 AM
All times are GMT -7. The time now is 12:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
