Originally posted by fujiste I have done some testings with or without SR enabled, but nothing was obvious altough it appeared just slighly better with it.
Under normal conditions, with a good camera hold you would not see any difference. SR only comes into play when the light is poor and you are trying to take images with a longer shutter speed than suggested. Or when taking shots that pan or have some other movement. Personally I consider shake reduction a crutch that should only be used when absolutely needed. A proper hold and brace along with paying attention to the shutter speed and other settings removes the need for SR in most normal conditions. Also it should NOT be used when mounted on a tripod as it will negatively impact the image. Just my humble opinion.
