Originally posted by zoolander I just set my K-3 to the highest it goes. When you set a limit, the camera won't shoot, and that annoys me. I'd rather it take a grainy picture than appear to be jammed up. Because then I get confused as to why its not firing, then I start hunting around in settings to see what I've done wrong. I'd rather see the picture pop up on the back of the screen for 3 or 5 seconds, and go yep, that looks yuck, and then adjust another parameter.
When I bought my first dslr (nikon) a friend told me to do just that, and not shoot above ISO 1600, the camera wouldn't take the picture, and I was confused. I do this even on my Fuji camera and max out the ISO so's that it always shoots. Unfortunately in Fuji the base ISO is 200, and when you broaden the ISO range it then starts at ISO 400 ....which is whats stupid about my fuji cameras.
Originally posted by MrB1 You appear to have found a setting that I have yet to discover. My camera (K-3 and K-70) is always able to fire the shot, however low the upper limit in Auto ISO.
OldChE - my K-70 is set at Auto ISO 100 to 6400 for grab shots. However, for considered shooting, I usually use manual ISO, setting it as low as feasible for the subject and scene.
Originally posted by whafrog That's what I do. For birds, where detail matters, even 3200 is a bit much for me, but I'd rather allow the shot.
Interesting thought about custom NR, I will have to try that out.
Thanks to all for your comments.
I've not found that the camera refuses to shoot whatever the max ISO, but if I leave the Max ISO at a very high value it tends to push up the ISO and shoot at a rather fast shutter speed. I'd rather it drop the shutter to a slower speed, since the stabilization works so well (i.e., rather shoot at 1/15s at ISO 400 vs. 1/120s at ISO 3200).
I too was using 6400 as my max ISO, but after some testing I think the quality is acceptable at higher for my purposes, at least in general, so I think I'll try 12800 for a while. As the rest of you have said, on occasion when I'm particular about image quality I'll shift into manual ISO anyway.
I found the advice on the custom NR settings here on the forum.
I should have indicated that I'm usually shooting in JPEG.
Thanks --> Richard.
