The weekend weather wasn’t very inspiring to pop out with the recently acquired K-70 but I took the opportunity to check out the remote release options for use on a tripod.
With my K10 I was using a cheap IR or a cable release so I thought I would give them a try on the K-70.
IR not working with either camera, I haven’t used it for quite a while so assuming a flat battery, back to that one later.
My cable release is a modified CS-105 for an MZ. To use it with my K10 I had chopped off the special MZ plug and fitted a 3.5mm stereo jack which then plugged into a further length of cable with a 3.5mm female socket to a 2.5mm jack for the camera. The idea being that I can add length using a standard 3.5mm headphone extension cable.
Using the cable release with the K-70 works fine, it auto detects the cable release and the two stage focus then shoot function works fine. The only thing I have found is that it ignores the 3 second delay option when selected in the menu and fires immediately. Has anyone else found this? Not sure if this is a conflict with another setting elsewhere. There are just so many menus to play with!
I really like the Mirror Up option for tripod work especially as there is an option to automatically disable SR. With my K10 I sometimes forget to disable SR or re-enable after tripod use.
I’ll try the Image Sync app and other Wi-Fi options when I have a spare moment.
