10-04-2018, 04:05 AM   #1
HDMI output issue – resolved!
I’m still getting used to work with the K-70 and thought I would try a bit of video.
As I was doing this in my ‘art studio’ (aka storeroom behind garage) I thought I’d try connecting it up to a computer monitor using an HDMI cable. Unfortunately there was no output on the screen. I know the lead is OK as I use it with my tablet that also has a micro HDMI output.
Initially I thought the output might be turned off in one of the many setting menus but having read through the instruction manual and poked around in the menu system I couldn’t find anything.
Having returned to this a few days later I now realise the issue was with the HDMI plug not pushing fully into the socket. There isn’t much space above the socket in the recess on the side of the K-70 and I found the plug just a little too wide to fit properly. Some careful trimming of the plastic plug with a craft knife means it will now fully insert and I have output to the external monitor.
10-04-2018, 08:54 AM   #2
Otis Memorial Pentaxian
QuoteOriginally posted by WillHG Quote
I'm glad you get it worked out!
This is a common problem with the cable ends for micro HDMI and is not limited to Pentax.
10-04-2018, 09:52 AM   #3
Not a Number's Avatar
Some people have found the same problem with some microphone plugs and the solution is the same.
hdmi, hdmi output issue, issue, k-70, k70, output, pentax k-70, plug, socket
HDMI output same as LCD in live view? VE2CJW Pentax K-3 2 04-17-2014 09:52 AM
K5 > HDMI output > Nexus 7? ChrisN Pentax K-5 6 05-08-2013 07:27 AM
K-01's HDMI output pundit Pentax K-01 2 03-17-2012 04:51 PM
K-7 and HDMI output while liveviewing barondla Pentax DSLR Discussion 3 06-14-2010 04:54 AM
Does K7 support HDMI output while recording video? johnmflores Video and Pentax HDSLRs 2 01-22-2010 08:04 PM
All times are GMT -7. The time now is 02:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
