08-23-2019, 09:34 AM   #106
Otis Memorial Pentaxian
QuoteOriginally posted by photogem Quote
No, this is not at all the case:
Thank you for your experience. Others have reported otherwise. A difference in live view vs. optical viewfinder is not diagnostic, but inappropriate stop-down (even once) is significant for both cases.
08-23-2019, 10:21 AM   #107
And where have others reported "otherwise"?
Here in this forum?
Can you supply links?
08-24-2019, 01:43 PM   #108
Sadly the firmware reset did not fix it. A new symptom has shown up post firmware reset though and that is that pictures taken with OV now are dark as ever but when he takes photos with LV, they are fine.
By the way, the aperture test Steve posted a while back for testing for the aperture block problem showed that the aperture does not open super wide when it is set to F4.5 either both before and after the test.
08-24-2019, 05:43 PM   #109
QuoteOriginally posted by tanz Quote
I will add this report regarding your dad's camera to the list. Was f/4.5 the maximum aperture for your dad's lens? It is important that the camera is set to not close the opening at all for exposure. Anything other than staying wide open indicates a problem. The test should also be not be done in live view.
Post back here with any news regarding repair or other cure. If still under warranty, sending it in for repair might be a good option.
08-29-2019, 06:00 PM - 1 Like   #110
Precision Camera just replaced the “aperture control assy” and “resistor chip” on my k-70.
The nearly black images in all auto modes are gone. Exposures are now correct and the repair was performed astoundingly quickly.
08-29-2019, 06:27 PM   #111
QuoteOriginally posted by rwhynacht Quote
Thanks for the update. The replacement of the "resistor chip" is something new.
09-09-2019, 07:24 AM   #112
So just had the black death on my K70 - sorry - possible aperture issue.
If I set the F-stop wide open (3.5 on this lens) and look in while on bulb mode the aperture is closed as much as it can be.
I held the shutter down to take a series of pics in auto of same scene and I got 3 very dark exposures followed by 2 correct then another dark. Seems to sometimes work.
I'm on holiday at the moment, so can't get to a repair station.
Spent the day in aperture priority mode or Tav with aperture set closed and pics looked as good as can be expected for a closed aperture.
Tried live view and as others experienced, the few I took seemed to work normally (there were a couple over exposed).
Tried 35mm prime rather than kit 18-135mm zoom with same result.
I bought March 2018 so 18 months ago and out of warranty (I suspect). Not happy! I don't know how to see number of shutter releases but I'm not a heavy user.
09-09-2019, 09:54 AM   #113
UK is still part of the EU and anyway you have your 2015 Consumer Rights Act which goes further than the EU 2-years warranty if pushed rightly through:
But even under EU law you have 2 years, so go for it:
FAQs - Guarantees and returns - Your Europe
Any company within the EU giving just 1 year warrany tries to wiggle out of their duty! They hope people believe it and give in.
Shuttercount: Google shuttercount + Pentax and you find it
09-09-2019, 02:46 PM   #114
Shutter Count 2,680
Manufacture Date 2017:09:14
I'll be checking details about warrenty once I'm home at the end of the week. It was an ebay purchase - albeit a new camera.
09-09-2019, 02:48 PM   #115
Sample photo attached. This was bright sunlight.
PENTAX K-70  Photo
09-09-2019, 05:08 PM - 1 Like   #116
QuoteOriginally posted by riverrock Quote
Welcome to the Pentax Forums!
I'm sorry to see that you are having problems, but thank you for visually confirming that your camera fails aperture control as the most likely cause. I have added your camera to the list in the original post. With any luck, you may still have warranty rights and are able to get this fixed at minimal expense. If you get the camera fixed, it would be very good if you were to post back here with what repair was done. Thanks in advance and good luck!
aperture control, aug, block, camera, cause, change, date, dates, diaphragm control, exif, exposure, failure, inconsistency, k-70, k70, message, pentax, pentax k-70, photo, reports, sept, solution, steve, thread, unit
Q1 2019 Financial Reports - Pentax still not doomed. Kunzite Pentax News and Rumors 217 08-05-2019 12:23 PM
Bright sun, underexposed pics. Where did I get the settings wrong? lushdimple11 Troubleshooting and Beginner Help 43 11-03-2018 11:15 PM
Underexposed Photos K1000 sonygoup Pentax Film SLR Discussion 13 02-24-2018 09:16 AM
Action Full Body Portraits - How Do I Avoid Underexposed Legs? reivax Photographic Technique 27 12-14-2017 10:54 PM
Underexposed viewfinder, normal LiveView iwtgbtp Pentax K-30 & K-50 4 03-10-2017 10:15 AM
All times are GMT -7. The time now is 02:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
