12-10-2018, 05:00 AM   #1
Dark images
Pictures taken with my K-70 are coming out very DARK. I've checked the exposure settings and Exposure Compensation, but nothing wrong. Camera was OK last week and just started giving dark pictures yesterday. I,ve been through my instruction book and even tried the Reset button to give the 'original' settings, still no joy!
It looks like there is a software fault somewhere. Has anyone had this happen to them? Please Help!
12-10-2018, 05:12 AM   #2
photolady95's Avatar
Location: Cruising PentaxForums and watching your back.
Could be the problem our K-30s and K-50s are experiencing. Aperture block failure, that's how it starts, black frames. Is this how it is with your K-70?
Might want to read here:
https://www.pentaxforums.com/forums/151-pentax-k-30-k-50/370666-dark-exposur...-me-first.html
And there has been other reports of the K-70 experiencing the same problem.
https://www.pentaxforums.com/forums/193-pentax-k-70/377096-k-70-underexposed-photo-reports.html
12-10-2018, 11:20 AM   #3
FozzFoster's Avatar
Welcome to the Forums!
Could ya post sample photo that includes exif data?
12-10-2018, 11:36 AM   #4
retired sw engineer
reh321's Avatar
QuoteOriginally posted by Eric Hall Quote
@FozzFoster is correct. A dark image posted here would be very informative.
@photolady95 is also correct; we have not heard very many Dark Image Syndrome cases reported here, but DSI takes time to develop. The 'gold standard' diagnosis procedure is to observe the aperture mechanism {"iris"} as you take a photo - if the body thinks the aperture is set to the widest value available, the "iris" should remain wide as you take the photo ..... it will shut tight if you have an aperture control issue
Diagnostic is to set to M mode with aperture set wide open with a 1s shutter speed, AF off. Observe the lens from the front while pressing the shutter button. If the lens stops down, there is an aperture control problem. Whether it is the aperture control block requires a more intensive diagnostic; fault may be in the camera electronics.
12-10-2018, 12:05 PM   #5
Otis Memorial Pentaxian
QuoteOriginally posted by photolady95 Quote
It would be good to note that none of the reports to date (5 total) have been confirmed as aperture block failure, meaning that a camera when sent for authorized service was repaired by replacement of the diaphragm control block (the component that failed on the K-30/K-50). I know it is a small matter, but the implications are important in that broad claims have been made regarding the K-70 and vulnerability to this sort of problem. So far, the reports thread has been pretty quiet with none of the original reporting members having closed the circle for their cameras.
12-10-2018, 12:15 PM   #6
Welcome to the Pentax Forums!
Hopefully, this problem can be resolved as something other than a hardware failure of your camera.
12-11-2018, 06:54 AM   #7
Dark Images from K-70
Hello Pentax Forum, thanks for the reply. After browsing various threads on 'Dark Images etc. I found a link, similar to the one you sent me, about 'Aperture Blocking'. I now think this is the most likely cause of my problems, because I performed the 'iris' test on 'Manual' setting for 2 seconds at full aperture, and observed the iris closing down fully when I pressed the shutter.
Furthermore, my K-70 is still under 12 Warranty, so I am going to return it for repair. Thanks for your help.
Images taken yesterday on my K-70 are attached. These were taken as RAW DNG's and converted to jpg resolution 72 and quality 8. No corrections applied.
PENTAX K-70  Photo
PENTAX K-70  Photo
12-11-2018, 07:03 AM   #8
You're welcome for the help. Your camera being under warranty will get it fixed for free.
12-11-2018, 09:22 AM   #9
I am glad you are still under warranty. Let us all know what they do for the repair.
dark images, exposure, exposure fault, k-70, k70, pentax k-70, pictures, settings
Dark circle in images from Tamron 17-50 f2.8 RobG Troubleshooting and Beginner Help 21 05-23-2018 07:47 PM
K-50 Dark Images john4str Troubleshooting and Beginner Help 7 07-14-2017 09:33 PM
Pentax K500 dark images. Please help! zburatoru Troubleshooting and Beginner Help 10 01-05-2017 06:23 AM
Pentax K-50 Dark images Deirdre Troubleshooting and Beginner Help 7 08-04-2016 11:09 PM
Nature Dark, dark skies and dazzling sunlight newmikey Post Your Photos! 4 10-14-2012 10:17 PM
All times are GMT -7. The time now is 05:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
