01-14-2019, 08:44 AM   #1
K-70 - How to select the AF-C mode?
This may sound a bit of a "gormless" question coming from a longtime user of the GX10/K5/K-30/K-3 bodies:
I've always used AFC mode as the default, but now, having just got a K-70, I can't work out how to get it out of AFS mode and then into AFC mode - When I press the INFO button, the AFS mode box can't be changed, and I can't find anything (yet) in the Menus or the Manual (yes, I did look!) on how to do it!
So, please can someone enlighten me on what to do?
PS: Although it arrived from SRS Microsystems today, I was surprised to find that it is still running the original V 1.00 f/w, and so I've downloaded V1.11 and wili install it later this afternoon - will that make any difference?
Thanks in advance.
01-14-2019, 08:53 AM   #2
microlight's Avatar
Record menu 1, first item?
01-14-2019, 09:05 AM   #3
pschlute's Avatar
QuoteOriginally posted by jeallen01 Quote
I think that is quite usual. Don't think I have ever bought a camera with anything other than the original firmware.
01-14-2019, 09:07 AM   #4
QuoteOriginally posted by microlight Quote
Thx but can't seem to find that option (the K-70 menus are slightly different from the K-3 &K-30/K-50 so that might be why).
01-14-2019, 09:30 AM - 1 Like   #5
Docrwm's Avatar
According to the manual it depends on what mode you are in which AF settings are available.
01-14-2019, 09:46 AM   #6
QuoteOriginally posted by Docrwm Quote
Thanks and that prompted me to actually "think" a bit - and the answer was "obvious" when I took another look at the mode settings on the dial on the top of the body, where "Programme" mode (which I virtually never use) was the setting as delivered.
However, when I reset that to my normal TAVR mode and pressed the Info button, then, in the AFS box, I could select AFA, AFS or AFC = "Job done"!!
Many thanks again!!
01-14-2019, 09:54 AM   #7
Docrwm's Avatar
Many thanks again!!
We've all had moments like that - glad it works and enjoy your new camera!
01-14-2019, 10:28 AM   #8
microlight's Avatar
It was from the K-70 manual - but congrats on getting it sorted. Enjoy!
01-14-2019, 10:45 AM   #9
In the manual = Yes. Easy to track down = "probably not" (like many Pentax manuals)
01-14-2019, 11:21 AM   #10
Docrwm's Avatar
They're easy - just Google "Pentax Camera Manual" and one of the top 3 links will lead to the list at Ricoh-Pentax.
01-14-2019, 12:55 PM - 1 Like   #11
mcgregni's Avatar
He probably meant its not easy to find things in the manual.
01-14-2019, 12:56 PM   #12
Quite, but I had already done that and downloaded the official manual, and then tried to find the solution via that (said that in my first post!) - but then I "gave up" and asked the question here. Lo and behold, a few minutes later the "penny dropped" and I found and sorted the problem!
---------- Post added 01-14-19 at 08:00 PM ----------
QuoteOriginally posted by mcgregni Quote
Absolutely!
afc, afs, k-70, k70, mode, pentax k-70
AF Spot mode: hidden fact revealed - AF point is 30% smaller than in "select" beholder3 Pentax DSLR Discussion 17 09-14-2018 12:15 AM
K-5 IIs forgets it's in AF Select mode geomez Pentax K-5 5 08-10-2013 07:14 PM
Spot AF vs Select AF szmatefy Pentax K-30 & K-50 3 01-20-2013 12:20 AM
AF Select mode. Am I missing something? Codazzle Pentax K-01 3 12-23-2012 01:04 PM
Select Mode AF Area Size Adjustment? Accuracy chaosteo Pentax K-01 3 07-12-2012 08:25 AM
All times are GMT -7. The time now is 12:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
