03-30-2019, 04:31 PM   #16
As c.a.m has suggested in post #14, check the Clarity setting in Camera Menu 3. If it is set to anything but zero, it slows down the burst to about 1 shot every 5 seconds.
Philip
03-31-2019, 05:09 AM   #17
Looks like you still have the portrait corrections enabled, which take a lot of processing time after each shot. You will wan to disable that as well.
You mean the skin tone probably. I'll switch that off, as well later. It makes sense.
Thank you Adam
---------- Post added 03-31-19 at 05:19 AM ----------
What mode is the main camera mode dial set on?
It's on manual mode. But I tried all modes.
04-05-2019, 09:37 AM   #18
c.a.m's Avatar
QuoteOriginally posted by efo_777 Quote
Continuous shooting mode isn't working.
Hi @efo_777, wondering whether you had any success in getting continuous shooting mode to work?
- Craig
04-06-2019, 01:06 AM   #19
Hi Craig, last time I tried after some suggestions, it started working but in very short buffer like 5-6 shots and then it gets much slower. As I have long hours working during the day, I haven't had much time to try on a stronger light. In a few days I will when I'm off.
Anyway I've never imagined that the burst mode would be affected by so many other settings. I wonder if it's only with Pentax this problem or with the other cameras, too.
04-06-2019, 03:37 PM   #20
c.a.m's Avatar
Hi Craig, last time I tried after some suggestions, it started working but in very short buffer like 5-6 shots and then it gets much slower. As I have long hours working during the day, I haven't had much time to try on a stronger light. In a few days I will when I'm off.Anyway I've never imagined that the burst mode would be affected by so many other settings. I wonder if it's only with Pentax this problem or with the other cameras, too.
I would guess that your K-70 is functioning correctly.
Just another thought -- 'slower' memory cards (i.e., lower write speeds) can cause slower buffer clearing times, and may limit the length of bursts in continuous shooting mode. Another factor is the type of file that you save to the memory card: Saving RAW + JPEG files will fill the buffer faster and hamper continuous shooting performance, than if you save only JPEG.
Hopefully you're able to get along okay with the settings that you've optimized for continuous shooting. It would be great if you could provide an update when you get a breather from work and have a chance to play with the camera.
Cheers,
- Craig
05-02-2019, 07:13 AM - 1 Like   #21
It's not because of the memory cards or the type of files I shoot, because I shoot with the same card and in both raw and jpeg it was ok. I had some more time so I kept changing settings and I think the main reason for the issue was the filters in camera. When I finally managed to shoot in burst mode I saved the settings in all 3 customizable programing modes just in case if I loose it again. It's a good camera I'd say but sometimes I think the mennue could have been a bit simpler. Thank you everyone for your help!
burst, burst mode, button, camera, continuous burst, continuous drive, continuous shooting, corrections, drive mode, fast shooting mode, framerate, high speed shooting, k-70, k70, lens, mode, pentax k-70, post, post a photo, press, selection, shot
Best autofocus mode to use with high-speed continuous shooting? Aerlind Pentax K-3 & K-3 II 14 04-29-2017 02:03 PM
Why GoPro’s Success Isn’t Really Isn't about the Cameras interested_observer General Photography 16 07-01-2014 05:05 PM
Continuous Shooting, Exposure Bracketing, Interval Shooting etc in B Mode! kamayok3 Pentax DSLR Discussion 8 02-12-2014 01:45 PM
Which mode are you? Single shooting or continuous shooting? RonakG Photographic Technique 39 03-06-2011 02:08 PM
All times are GMT -7. The time now is 03:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
