03-29-2019, 03:06 PM   #1
Continuous shooting mode isn't working.
Hi everyone. I don't know if there is some problem with the camera or I did something with the settings but I can't shoot in burst mode any more. The camera shoots one single time and that's it. I tried to change every single setting but with no result ... Does anyone know what it could be? Thank you very much in advance.
03-29-2019, 03:09 PM   #2
amoringello's Avatar
Which camera, and are you able to select continuous shooting mode? i.e. is the option not available, or is it single-shot even though you have continuous shooting enabled?
03-29-2019, 03:22 PM   #3
I'm using Pentax K-70.
Yes, continuous mode is enabled. Everythings look ok but it just does'n shoot that way at all. Only one shot and that's all.
---------- Post added 03-29-19 at 03:38 PM ----------
I noticed now that if I keep enabling the Continuous shooting (High or Low) the only icon in green, that is the one active, is still the Single frame shooting. All the rest are in white.
03-29-2019, 03:46 PM   #4
QuoteOriginally posted by efo_777 Quote
I don't have the k70 specifically, but the green icon for single frame is like that to say that if you press the physical green button, it sets it to that mode. What is selected should have a frame around it (and you press OK to select it)
To take autofocus out of the equation (depending on the settings the camera may not fire unless it acquired focus), set the focus to manual, select from the drive mode continuous shooting, and hold the shutter button. The camera should fire at a steady rate. If that's so, then you should tell us more about what kind of subject you're trying to shoot, perhaps it's caused by AF not locking focus (good news is that there's a lot of useful info in PF about technique for tracking motion)
03-29-2019, 04:04 PM   #5
I've tried this many times including auto focus adjustments. Could it be because of the low light?
I actually noticed it this evening when I was trying to shoot some parrots in the park but even if it was a still object it shouldn't be a problem as I have done this before. I don't know what happened.
03-29-2019, 04:15 PM   #6
Can you post a photo of your drive mode menu?
03-29-2019, 04:23 PM   #7
UncleVanya's Avatar
What mode is the main camera mode dial set on?
03-29-2019, 04:49 PM   #8
Yes, here how it looks like.
---------- Post added 03-29-19 at 04:51 PM ----------
It's on manual mode but I tried the others modes, as well.
SM-G930F  Photo
SM-G930F  Photo
03-29-2019, 05:01 PM   #9
Here are 2 more photos
SM-G930F  Photo
SM-G930F  Photo
03-29-2019, 05:12 PM   #10
Caver's Avatar
... I don't have a K-70 - but maybe it is in focus priority - so it wont take a shoot until focus is fixed - thus in lower light or challenging situations it wont shoot continuously...
03-29-2019, 05:15 PM   #11
It looks like single shot is still selected. You will need to press the OK button to confirm the burst mode selection.
Also, if you have lens corrections on, this will slow your burst framerate.
03-29-2019, 05:22 PM   #12
QuoteOriginally posted by Caver Quote
I set everything in release priority. As far as I checked everything its not on focus priority. I'll see tomorrow during the day. Hopefully you are right about the low light. Thank you.
03-30-2019, 02:00 AM   #13
It looks like but I dont know why. I keep selecting burst mode as it is shown on the screen control panel. I'm attaching a photo.
---------- Post added 03-30-19 at 02:18 AM ----------
I turned off all lens corrections now. It just wont shoot a second shot...
SM-G930F  Photo
03-30-2019, 06:49 AM   #14
c.a.m's Avatar
@Efo_777, perhaps this is a clue:
Continuous shooting cannot work if clarity function is enabled - PentaxForums.com
https://www.pentaxforums.com/forums/184-pentax-k-s1-k-s2/316825-help-continu...ting-mode.html
Also, the user manual, pp. 118-120 of the English language version, indicates some restrictions for continuous shooting.
The camera might be set to a function that doesn't preclude continuous shooting, but slows down the burst rate significantly. Have you tried holding down the shutter button for several seconds?
- Craig
03-30-2019, 01:15 PM   #15
Looks like you still have the portrait corrections enabled, which take a lot of processing time after each shot. You will wan to disable that as well.
burst, burst mode, button, camera, continuous burst, continuous drive, continuous shooting, corrections, drive mode, fast shooting mode, framerate, high speed shooting, k-70, k70, lens, mode, pentax k-70, post, post a photo, press, selection, shot
Best autofocus mode to use with high-speed continuous shooting? Aerlind Pentax K-3 & K-3 II 14 04-29-2017 02:03 PM
Why GoPro’s Success Isn’t Really Isn't about the Cameras interested_observer General Photography 16 07-01-2014 05:05 PM
Continuous Shooting, Exposure Bracketing, Interval Shooting etc in B Mode! kamayok3 Pentax DSLR Discussion 8 02-12-2014 01:45 PM
Which mode are you? Single shooting or continuous shooting? RonakG Photographic Technique 39 03-06-2011 02:08 PM
All times are GMT -7. The time now is 06:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
