04-07-2019, 05:50 AM   #1
Developing RAW Images In-Camera
I have a RAW image that I want to test different camera settings to ‘fix’ it and then convert to a JPEG image.
I am not sure what I am doing wrong but when I try to convert the RAW image to a JPEG in-camera I get an error saying that “No image can be processed”. I press the playback button and select the image. I then press the WB button to bring up the Raw Development screen and select the icon with RAW and a down arrow. I then choose the ‘Select single image’ option and get that error message. My first thought was that the SD card was in write protect but it was not. I checked the manual and also did a search for the solution but found nothing. Thanking you in advance for any help with this issue.
04-07-2019, 08:11 AM   #2
CarlJF's Avatar
It might sound obvious, but have checked the camera is set to save in RAW or RAW+JPG and not JPG only ? If using dual memory card in RAW+JPG, are you sure to select the SD card with the RAW datafiles and not the JPG one ? This last one happened to me countless of time and will give the error message that you see.
04-07-2019, 08:19 AM   #3
Thank you for the reply CarlJF. Apparently The K-50 and K-70 RAW formats are not compatible in-camera. I shot the RAW file on my K-50 but when I learned about the option to fix the photo in-camera I copied the file onto the K-70 card. Well that doesn't work. I copied it to the K-50 and 'fixed' my issue...which in this case was me ;o)
04-07-2019, 01:54 PM   #4
UncleVanya's Avatar
QuoteOriginally posted by Tewhano Quote
I think the in camera raw has only the profile for the sensor in that exact camera sensor.
button, convert, error, image, in-camera, incamera, jpeg, k-70, k70, pentax k-70, press, raw, select
LR vs AP RAW developing engine: curious to know other folks feedback. aitrus3 Digital Processing, Software, and Printing 6 06-19-2018 06:12 AM
RAW image developing comparison vzbx Digital Processing, Software, and Printing 20 10-02-2014 03:06 PM
Why do RAW my RAW images not look great... pjthiel Digital Processing, Software, and Printing 23 05-17-2011 07:00 AM
RAW duplicate images - saving as RAW files jpzk Digital Processing, Software, and Printing 17 02-15-2010 07:01 PM
RAW, Raw, or raw? stewart_photo Pentax DSLR Discussion 10 01-22-2009 07:14 PM
All times are GMT -7. The time now is 05:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
