04-26-2019, 03:32 AM   #1
Barrington's Avatar
Lens calibration
Something I've never done and really only just become aware of . I'm expecting my new K-70 and 50mm f1.8 today or tomorrow , is calibrating something I need to do or check ?
Thanks
04-26-2019, 03:43 AM - 1 Like   #2
pjv
Otis Memorial Pentaxian
pjv's Avatar
QuoteOriginally posted by Barrington Quote
Thanks
It is worth a check.
Fixing Front and Back Focus - Introduction - In-Depth Articles
04-26-2019, 04:07 AM - 1 Like   #3
SharkyCA's Avatar
Thanks
Here is a couple of articles on lens alignment/focus:How To Calibrate Your Lenses | A Simple Fix For Blurry Images (2019 Update)
https://photographylife.com/how-to-quickly-test-your-dslr-for-autofocus-issues
https://photographylife.com/how-to-calibrate-lenses
Last edited by SharkyCA; 04-26-2019 at 04:12 AM. Reason: add a link and update message.
04-26-2019, 05:04 AM - 1 Like   #4
K(s)evin's Avatar
Get out and enjoy your new gear! Take lots of photos in order to familiarize yourself with the camera. Make sure that your technique is solid. Ask lots of questions here on the forum. And don't worry about lens calibration right away. If, after taking lots of photos and finding a consistent problem with getting in-focus results, then consider calibration. Inquire here about proper testing methods. But beware. Make absolutely sure that you understand how Pentax AF is supposed to work. Be confident in your shooting technique.
In 10 years of shooting with 5 different models of Pentax DSLR, and too many lenses to count, I have yet to calibrate a single lens. Maybe I've just been lucky. I don't know. Just try to be sure that you have eliminated any other possible cause.
04-26-2019, 05:14 AM   #5
Barrington: Making pictures should be fun! So take your new equipment and enjoy it.
I have been shooting with Pentax cameras and lenses for more than 12 years (approx 5 cameras, 20 lenses) and I have never needed any lens calibration. Once I let my new camera AF system calibrate.
04-26-2019, 05:50 AM - 2 Likes   #6
Barrington's Avatar
Thanks guys , in my OP when I said I hadn't been really aware of calibration it was only when I was researching lenses for my K-70 I came across it , so I thought I'd ask .
---------- Post added 04-26-19 at 01:51 PM ----------
Oh btw the camera & lens have arrived , currently charging the battery
04-26-2019, 06:52 AM - 1 Like   #7
While your camera has an AF fine adjust feature (it is the camera that is adjusted, not the lens), the process of doing so can be tedious. I vote with those above who suggest getting out and enjoying your new kit. If there are problems with persistent missed focus, such will be apparent in the first few days of use.
Have fun!
04-26-2019, 08:20 AM - 1 Like   #8
pschlute's Avatar
Whilst i agree with those who say get out and start taking pictures, there is a place for camera/lens calibration.
Fine adjustment of AF began to appear in cameras as the megapixels of our sensors got more numerous and we were able to see detail that was not possible in early digital or before that film cameras. Basically the shortcomings of the Phase-Detect autofocus systems (viewfinder method) were revealed. PDAF tolerances when built at the factory can vary, and the accuracy of the system is not 100%. (Live View is not affected as the focus is done directly on the sensor itself.)
My K-1 was not giving me what I wanted when I first purchased it, and never having had a AF/FA system in a camera before I was stumped. i need to adjust +8 on average to achieve perfect AF behaviour with my lenses. It will vary by camera, so if the OP does feel that his pictures are not as sharp as they should be when viewed at 100%, there is an easy solution.
04-27-2019, 03:59 AM   #9
Barrington's Avatar
Hi Peter , where is that adjustment found ?
Ok I've found it
02-07-2020, 06:51 AM   #10
dlh
F.O.G. (fat old geezer)
dlh's Avatar
Alternative method, clever, but I think I'll stick with my own.
My method is to lay a 4' ruler at an (~=45 degree) angle against something solid in a well-illuminated place, move the camera back a ways (paying attention to the range of any zoom values and the minimum focusing distance) and take pictures of a particular point on the ruler (which I usually mark with a black binder clip). I set the aperture somewhere in the center of the range for the lens being tested, figuring that's where the least distortion will occur. I take four pictures, two with manual focus through the viewfinder, and two with autofocus through the viewfinder. Two of each because I rotate the focus ring all the way to the left for one before refocusing, and the other all the way to the right. Then I can see the range of what's in-focus on the ruler, and adjust the camera based on my estimate of what it'll take to get the center of that range to where the paper clip is, repeating the process as necessary. Two or three tries is generally sufficient.
k-70, k70, pentax k-70
Lens focus calibration guidelines ismaelg Pentax SLR Lens Discussion 22 02-22-2019 06:52 PM
Lens focus calibration function suggestion/wish! victormeldrew Pentax DSLR Discussion 9 09-12-2016 09:31 PM
Automatic Lens Calibration - Would this Work? ablundon Pentax DSLR Discussion 11 12-21-2014 01:27 PM
K5 lens calibration for Ronikon 85mm f1.4 James78 Troubleshooting and Beginner Help 34 09-22-2014 05:07 PM
"Ghetto" Lens Calibration Chart EarlVonTapia Pentax SLR Lens Discussion 7 04-20-2013 12:12 PM
All times are GMT -7. The time now is 04:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
