Originally posted by rwhynacht Since returning from vacation I was able to test my k-70 with multiple lenses. All lenses produce dark images in all the auto modes. Manually setting aperture ring on vintage lenses to the metered readings produced ok images every time.
Not sure why I was initially getting better results with live mode- but that has now failed as well and dark images result from both modes.
I am sending the camera for repair under mastercard extended warranty and will post an update once it comes back. In future will travel with an old manual lens so i can take at least a few vacation photos if/when it fails again.
The update never arrived here in this thread, but "rwhynacht" mentioned the outcome here, when he wrote:
2 months ago I got the aperture assembly replaced on my K-70
So after all predictions: It was just the solenoid which failed
which in a way he explained here:
Originally posted by rwhynacht Shooting a K-70 for over a year. No exposure problems. Today began getting nearly black images in all modes: AV, TAV, M, Auto. My 1st thought was aperture block failure but after some testing found live view appears to expose correctly. Optical view is around 5 stops under exposed. Also pop up flash shots are equally under exposed in both modes. I have only 1 lens with me currently (Sigma 17-50 2.8) so I have not tried an older manual lens yet, but I doubt it's lens or app block related. Any thoughts?
LiveView does often work when the solenoid is not working anymore.
The K-70 (and K30/50 K-S1/2) use f4 preset for LV metering but actually the aperture is fully closed and yet the camera can meter.
The solenoid actuates twice in LV and receives more mA for the second actuation.
