Originally posted by PentaMiCL I don't mind that the mechanical shutter actuates, say, at the beginning and end of a round of continuous shooting, for example. If the mechanical shutter actuates as many shots as I take using the electronic shutter, that would be pointless. In short, if I can take multiple-exposures using a (the?) silent mode, that would be ideal.
I think the other big difference between the Kp and K-70 is the aperture mechanism. On the Kp this uses a separate stepper motor, so the aperture can step down for each shot, even if the mirror stays locked up. On the K-70, the same motor performs both functions, so the aperture cannot stop down without the mirror cycling.
Theoretically, you could use the aperture stepped down with the mirror locked up to take a burst of shots. However, the view finder would be dimmer between shots as the aperture would never open back up. Consequently, I think this may be why Pentax doesn't offer the silent shutter on the K-70.
Incidentally, I did try using pixel shift resolution on a K-3 II in live view, to see if the shutter would remain open. However, it did cycle the mechanical shutter before the sequence of shots (to clear the sensor), so no such luck.
