11-30-2019, 04:34 PM   #1
Pentax K-70 - is it possible to disable shake reduction?
Hello,
I'm considering buying Pentax K-70 online, however one feature (or the lack thereof) is not clear to me from the PDF user guide.
Can the shake reduction be turned off if desired with this model?
I haven't found any mention about this possibility. I see in the PDF guide there is a shake reduction submenu, but I found no details about the options (whether it is on/off, or only different levels of "on" intensity).
Thank you.
11-30-2019, 04:39 PM   #2
Yes, you can turn it off with any Pentax model. It turns off automatically in some modes (timer, etc).
11-30-2019, 04:50 PM   #3
Timer and mirror lock up turn off the Shake reduction.
You can also turn it off in the menu. In the K-5 there is an option in the fourth tab of the Photo/Camera tabs. I can only assume that this is similar in the K-70.
I think you can even assign one of the function buttons to toggle it on or off.
11-30-2019, 04:57 PM   #4
Man With A Camera
Racer X 69's Avatar
QuoteOriginally posted by pentax2019 Quote
Hello,
Thank you.
Shake reduction on the K-70 can be turned off/on in the control panel.
To get to the Control Panel, press Info. Navigate the control panel using the right/left arrow keys (on the 4 way controller) to get to Shake Reduction icon, then use the rear thumb wheel to select the desired Shake Reduction status (off/on), then press OK to change.
12-01-2019, 01:41 PM   #5
QuoteOriginally posted by Racer X 69 Quote
Same goes even with older models like the K-7.
12-11-2019, 08:07 AM   #6
Hello,
Thank you.
Can I turn off shake reduction in a user programmed mode in the K-70?
I have a 150-500mm Sigma lens with built in SR, and I wouldn't mind having a "user defined setting" which would be a 2nd aperture priority setting with in body SR turned off.
12-21-2019, 04:32 PM   #7
rogerstg's Avatar
QuoteOriginally posted by sheld Quote
See post 4
01-08-2020, 12:51 PM   #8
Thank you very much for all your comments.
guide, k-70, k70, pdf, pentax, pentax k-70, reduction, shake
Is it possible to disable the green button? arkav Pentax KP 12 12-01-2019 02:22 PM
k 50 shake reduction shake jacques Visitors' Center 6 10-17-2017 11:07 AM
K5 II video shake mechanical or electronic shake reduction? Rice Pentax K-5 3 06-14-2014 02:51 PM
Disable Shake Reduction when using tripod? *Rich Photographic Technique 9 05-26-2013 02:54 AM
a possible full color hack for all bodies with shake reduction blade_o5990 Pentax DSLR Discussion 3 12-23-2009 07:15 PM
All times are GMT -7. The time now is 10:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
