Originally posted by The Apostle
Appreciate all the help. This thread saved the camera for sure. The battery fits a bit tighter than it did before, but the camera is up and running normal.
You are welcome.
About the battery fitting tighter:
The battery-compartment of the K-70 should actually not at all be affected by the disassembly/assembly but two parts could cause a tightness:
- the internal screw which some try to get lose which would be a mistake, because there is no need to do so and if, it would get jammed because it doesn't move freely but would screw into the side plastic of the compartment. I added that into the tutorial just in case, because the K30/50/500 and K-S1 do request that !screw to be lossened!
- the batteryhook sits on a beryllium-copper spring which might have been dislocated?
Originally posted by SharkyCA
Congratulations and Kudo's to @Photogem; for his input!
Thank you..... would have been a shame not to get such a great body properly repaired!
