Originally posted by CoolBreezeRandy I mostly shoot models in a studio at the moment (it's a club...a fun one). The owner has done a good job of lighting the place (strobes, banks of LEDs, etc), but the different locations for the models vary wildly (bright white, velvet black, and several in-between). I want to show-up the higher caliber Canons and Nikons I shoot against more consistently, but I'm still pretty green at serious photography, so I'm looking for personal experience and opinion: what should I be doing, as far as general camera settings, as well as that specifically pertaining to the K-70, to try to give myself an edge here? Any assistance is appreciated, thanks.
P.S: I shoot with a Pentax 18-135 at the moment.
Mate, you're going to take almost identical pictures to each other, with the same lighting and modifiers, the same position, the same background. That's why a real studio is so good. Even a little m43 camera will be for all purposes indistinguishable in its results.
There is so much power coming out of the strobes that you guys are in ideal situation to get fantastic, editorial quality images: start from f8 (it will probably be someone's job to use a light meter to ensure it's f8 at the strobe levels), ISO 100, and 1/180 or (better to prevent syncing lag errors with the triggers) 1/100s shutter speed. There will be no blur in your pictures, because there is only light coming out of the strobes for 1/1000s or less anyway.
