Originally posted by voicelit The K-70 doesn't seem to offer "Flash" as a White Balance setting option?
menu --> C3 --> WB when using flash
(from the manual...note that changing WB will not change brightness)
Originally posted by voicelit It seems to have less choices for flash strength than older models?
-2.0 --> +1.0 EV exposure comp in P-TTL auto mode, 1/1 --> 1/128 intensity in manual? I do believe those have been the norm for several years for Pentax built-in flash.
Originally posted by voicelit I can't figure out if High / low Key Aid Adjustment gets "darker" when increasing / going to the right or the opposite, same with "Highlight adjustment."
???? Are you talking about post processing?
Originally posted by voicelit I use "Natural" setting; is their a better one for flash / highlights: Ie: flat?
Natural should be fine. Those custom image settings only apply to in-camera JPEGs and do not modify exposure.
In straight language...the results from your example images are properly exposed by most standards for the subject and manual exposure settings.
The flash exposure is spot on in that the whites are white with detail present. The backgrounds look the way they do because that is how the camera was set up and because the flash maximum output is only GN 12(m)*. Example #2 looks the way it does due to subject movement. A full explanation would be involved, but it may be enough to say that less powerful flashes tend to discharge at or near full duration, meaning they may not be able to stop motion.
My suggestion would be to learn the limits of the built-in flash in a controlled setting using one of the automated exposure modes with the flash in regular/flash on (auto P-TTL) mode with a stationary subject. Try out different flash exposure compensation settings at different distances. The camera will do its best to balance flash and ambient light. From there you can move to manual exposure and manual flash where you have full control and adjust flash exposure using aperture and/or flash intensity (duration actually). You will likely need a phone app and/or some arithmetic to figure guide numbers and proper aperture settings.
I skipped using manual exposure and auto P-TTL flash despite it working quite well and is a very viable option. One needs to understand the relationship ambient light, distance and flash power before being able to manually balance using flash exposure compensation alone.
Good luck! Have fun!
* Meaning 3 meters at ISO 100 and f/4.0
