Originally posted by Emirena
the ISO got set to 3200 and the resulting overexposure and additional noise was very disappointing!
Yes, that is one of the hazards of using TAv mode.
Edit: We can blame the noise on TAv mode setting the highish ISO. The overexposure was probably metering.
Can someone let me know if de-linking the AE/AF points would help, and if there's a way to set AE point to scene average while retaining the AF point as a central spot?
The default is to have the two separate. If you are set to have them linked, uncouple them using:
menu --> C1 --> 5 Link AE and AF point
As for metering choices, they run as follows:
- Multi-segment (exposure based on scene evaluation over 77 segments)
- Center weighted (brightness of the scene is averaged with emphasis given to the center portion)
- Spot (exposure based on the center only)
My experience is that multi-segment works well for almost everything. Center weighted is good if your general subject is more in the center and stuff away from center might be present that will skew the metering. Spot metering is a specialized tool and is not appropriate for general photography. I think it is safe to say that the majority of help requests on this site related to poor exposure can be traced to use of spot metering or linking AE to the AF point.
(...uses spot metering to place exposure to a particular value when using M mode and never for anything else...)
