Originally posted by stevebrot Guys! The OP has a mirror failure!
It is something else.
It sounds like you have a mirror flipping up problem (sorry, could not resist). The aperture actuation and mirror mechanisms are related on your camera, but failure of the solenoid on the aperture control block does not affect mirror movement. That said, a failure of mirror control may result in failed aperture control due to shared mechanical parts. As noted above, if the camera is still under warranty, now is the time to use it. If not, a professional repair is your best option. Note that even if you use a shop local to you, they will likely send your camera to a Pentax-authorized service center.
Sadly I do not have a warranty - bought it used from Japan off of eBay. I haven't had problems with my Pentax cameras in the past, so I thought I'd give it a go. It is actually my wife's camera - she used it once and it worked fine about 6 months ago, and now it doesn't.
For what it is worth... I took the lens off, put the camera in manual, set the shutter speed to something slow, and lifted up the mirror with a small tool. When pushing the shutter release, I hear a couple of motors whir, but the shutter doesn't seem to open. So I have a mirror flipping a a shutter firing problem.
