11-20-2020, 10:04 AM   #1
Multi-Exposure With Remote
Taking some waterfall photos and experimenting with soft looking water. In the drive menu, I select Multi-Exposure - Remote Control and set composite mode to Average and number of shots to 0020. I have to click the remote 20 times for this to work, which it does quite nicely. However, is there a way to do the same averaging in camera and only have to click once to start the process? Thanks
11-20-2020, 10:21 AM - 1 Like   #2
Otis Memorial Pentaxian
Try using Multi-exposure with the Continuous option. You will have to hold the button down.
Alternatively, Interval mode with composite and a short interval is another option.
11-20-2020, 10:38 AM - 1 Like   #3
photoptimist's Avatar
You could change from "Multi-Exposure-Composite" (which requires one button-press-per-shot or holding the button down in continuous mode) to "Interval-Composite" (which requires only a single button-press to imitate an automatic timed series).
The only tricky bit with interval-composite (and also a problem with multi-exposure-continuous) is that if the time between shots is too short, then moving objects (flying blobs of water or floating leaves) end up as unnatural dashed lines or repeated objects in the composite image. The solution is to set the interval between shots to be long enough for any moving object in the scene to move a long way (preferably out of the frame).
11-20-2020, 10:45 AM - 1 Like   #4
Thank you
---------- Post added 11-20-20 at 10:45 AM ----------
Thank you
11-20-2020, 05:54 PM   #5
interval-composite mode.
button, click, interval, k-70, k70, mode, multi-exposure, objects, option, pentax k-70, shots
Multi exposure ? BarryE Troubleshooting and Beginner Help 13 09-05-2019 10:04 PM
Long exposure looks like multi-exposure Paul the Sunman General Photography 13 01-03-2017 09:43 PM
multi-cam setup, remote control solutions? Wired Video and Pentax HDSLRs 9 11-01-2014 02:43 PM
Long exposure shots, ND filters and multi-exposure averaging rrstuff Photographic Technique 17 10-19-2013 12:50 PM
HDR/Multi-exposure/Exposure Bracketing sany Troubleshooting and Beginner Help 4 04-24-2011 08:52 PM
All times are GMT -7. The time now is 02:15 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
