Originally posted by scotty1 I can't get my K70 to use Astrotracer in Bulb or manual mode. I do the calibration and make sure the GPS is on etc. I may try getting out of town to see if it's a GPS problem.
The only way I can get any success is with the user3 mode Astrophoto. I can get 20 seconds without startrailing with the 55-300 HD WR lens at 300mm.
I turned off noise reduction in this mode as I wanted the RAW files unedited.
I may try turning the inbuilt noise reduction on again, to see how the jpgs turn out for stacking.
With my K5 I can use the Astrotracer in Bulb mode, and use a remote to open/close the shutter as needed. It seems more straight forward with the K5.
Not quite sure what the question is … in Bulb Mode, the infamous Green Button switches from manual control to timed release, 10sec to 20min … not sure why one would need to use Manual for Astro' work.
Have you activated Astrotracer in the menu or on the control panel? … the User3 'Astrophoto' seems to do that by default.
I usually take the Astrophoto settings as a perfectly good starting point and set the exposure time to suit the combination of focal length, background pollution, working aperture and ISO.
The camera will limit the exposure time available depending on the focal length, but this setting seems to be only a compromise, as shutter speeds need to be shorter with the camera pointing near the celestial equator than they do to the celestial pole.
Depending on the number of exposures required, in-camera noise reduction can be very adequate, until such time as it starts to be a nuisance 'cos it takes longer than you'd like
At this point you can switch noise reduction off to save time making actual exposures, but you'll need to spend time at some point making 'darks' and 'flats' etc. later to compensate … very much an individual choice
I've only tried cameras other than my K-70 very briefly with the GPS module … the K-70 just seems to be so much easier to use, with it's fully articulated screen.
If I remember correctly, the K-5 has a reduced set of features, compared to the K-70, so that might be why it seems "easier" to use.
