01-11-2021, 08:22 PM   #1
Peak Focusing in LV
Hi everyone,
I'm still learning this camera, as i just purchased it a few weeks ago. I'm still trying to figure out if when using liveview, and then hitting the "OK" button to zoom in on an area to focus, can you get the focus to stay on that spot (while in AF). Seems like once you go back to the regular view and hit the button to take the photo, the camera re-focusses. Maybe this can only be done in Manual Focus?
TIA!
01-11-2021, 09:18 PM - 3 Likes   #2
ramseybuckeye's Avatar
QuoteOriginally posted by 87Duckfan Quote
Hi everyone,
TIA!
If you are using shutter release button to autofocus, once you have taken your finger off the half press, it will refocus when you press it again. That's one of the reasons so many people use back button focusing. I don't use the zoom magnification with autofocus, that's normally a tool for manual focus.
So if you set your camera up for back button focusing, your shutter button won't have to be dual purpose and it won't refocus when you don't want it to.
01-11-2021, 09:31 PM   #3
QuoteOriginally posted by ramseybuckeye Quote
For some reason, when I try back button focusing, and then hit the shutter button, it focusses again. Maybe I have a setting wrong?
Also, can't seem to zoom in to an area to focus. I can move the focus square to put it where I want, but then can't figure out how to zoom in more.
01-11-2021, 10:07 PM - 1 Like   #4
Paul the Sunman's Avatar
See page 107 of the K70 manual. You need to set AF2 to disable shutter button AF. (Camera 5 menu AF/AE-L button)
01-11-2021, 11:00 PM   #5
UncleVanya's Avatar
Canít you use the AF/AE-L button to lock focus also?
01-12-2021, 02:31 AM   #6
Michail_P's Avatar
You can set the back button to focus and at the same time the shutter button wonít. I havenít seen a lock option though. I generally prefer to lock the exposure while keeping the focus on the shutter button. I use peaking when in manual focus.
01-12-2021, 07:30 AM   #7
Fogel70's Avatar
You can also try back button manual focus, so that when you hold down the AF button you switch to manual focus.
That is how I usually have my cameras set up as I primarily use AF-S autofocus.
IMO back button AF is mostly an advantage if always using AF-C.
01-12-2021, 08:53 AM   #8
QuoteOriginally posted by Fogel70 Quote
Ok, I figured out how to use back button AF, and not have the main shutter button re-focus. However, I still have not figured out how to zoom in on a specific spot on LV, use AF to focus, then back out and hit shutter button to take photo. Maybe this can only be accomplished in Manual focus?
01-12-2021, 03:02 PM   #9
Michail_P's Avatar
Yes I guess. If you think about it, fine focus probably only makes sense that way.
01-12-2021, 03:42 PM   #10
QuoteOriginally posted by Michail_P Quote
The only reason I ask, is that I have seen a YT channel where the photographer uses a Nikon D7200, and he can zoom in, use auto focus, then back out and take the photo.
Would be nice if the K70 can do this also...
01-13-2021, 02:35 AM   #11
You must be in Select AF point mode, then move white square to where you want to focus. Don't know about K-70, but on K-3II it doesn't cover whole screen.
5 Days Ago   #12
So, can anyone confirm if this can be done on the K70:
Using LV,
Zoom in on spot in scene using spot focus/Select AF point. Then hit backbutton to focus or re-focus the image? This is when, for me atleast, the camera backs out of the "zoom", and then I can re-focus. But again, I was hoping to AF while zoomed in. I realize I can Manual Focus while zoomed in. Maybe I have a setting incorrect?
Hopefully this makes sense...
4 Days Ago   #13
SharkyCA's Avatar
Using LV,
Just for your info, I to use a K-70 and have found Yvonne's e book a great source of information!
https://www.pentaxforums.com/forums/donations/?ebooks=1&loginrequired=1#sub18
4 Days Ago   #14
Thanks for the info, however not sure that answers my question. It would be great if someone can confirm this can be done. I wonder if the KP can do it?
button, camera, focus, k-70, k70, pentax k-70
All There is to Know About Pentax & LV Electronic Shutter PentaMiCL Pentax DSLR Discussion 8 12-17-2020 12:26 PM
KP bug or KP Broken, Av Mode and Red Blinky Warning Text in LV BruceBanner Pentax KP 26 06-25-2019 05:06 PM
Focusing Screen or LV Aid or Tenpa 1.36 Magnifier? BruceBanner Pentax Camera and Field Accessories 17 06-28-2018 02:22 PM
Peak focusing, please explain slip Troubleshooting and Beginner Help 4 06-05-2012 11:45 AM
Macro setting LV focusing question emulsify Pentax K-r 13 01-28-2012 10:42 AM
All times are GMT -7. The time now is 06:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
