02-05-2021, 07:50 AM - 1 Like   #1
Pentax K-70 and Skywatcher StarAdventurer (and derivatives)
I have just purchased a SkyWatcher StarAdventurer 2i to enhance my astrophotography. I already have a remote timer and, of course, the K-70 has lots of timer options built in which I had intended to use.. However the StarAdventurer can control the camera plus the camera/StarAdventurer combination can then be controlled from an App over WiFi.
Whilst owners of Canon, Nikon and Sony etc. are generally well catered for by device manufacturers, Skywatcher appear to have forgotten us Pentax owners. Therefore there is no connect cable available for Pentax.
I did a bit of research, looking at the wiring diagrams for Canon cameras and Pentax cameras. I realised that the early Canon cameras had effectively the same signals on the tip, ring and sleeve of the remote plug. Ok so the Pentax is actually tip, ring, ring, sleeve but the Internet advice is that the sleeve and adjacent ring should be shorted together making them one for the correct operation of the Pentax shutter anyway.
Therefore the only difference is that the Canon is a 2.5mm plug and the Pentax is a 3.5mm plug. I purchased the Skywatcher Canon R1C Cable and a 2.5mm to 3.5mm stereo adaptor (Stereo because it naturally shorts together the sleeve and adjacent ring) and IT WORKS! I now have a Skywatcher StarAdventurer controlling a Pentax camera!
I should add that in the settings menu on the camera you need to manually set the input port to Remote Control as it does not auto-detect with this cable.
Posting this here for future reference for someone. I
Pixel 2 XL  Photo
Pixel 2 XL  Photo
02-05-2021, 08:19 AM   #2
Dan
Brilliant! Thanks for posting.
02-05-2021, 02:22 PM   #3
Michail_P's Avatar
Very thoughtful .
02-05-2021, 06:56 PM   #4
Otis Memorial Pentaxian
QuoteOriginally posted by mlines Quote
I'm glad it is working for you and surprised that SkyWalker does not list your Pentax K-70 as supported. It is pretty well-known that Pentax and many models of Canon cameras share a common simple plug logic. FWIW, the required plug is actually 3.5mm TRRS (four conductors instead of the three pictured).* That is probably why the camera did not auto-dectect. That said, if it works, it works!
I am looking forward to seeing your astro posts!
* The question of compatible plugs for the K-70 and KP has been discussed at length here. If I have time, I will find the one that provides the easiest solution.
cameras, canon, k-70, k70, pentax, pentax k-70, plug, skywatcher, sleeve, stereo
Ioptron smart eq 3200 pro vs skyguider pro vs skywatcher star adventurer? AI8877 Troubleshooting and Beginner Help 18 05-03-2020 09:49 PM
Compare DA 70 with DFA* 70-200 @ 70 Paul the Sunman Pentax SLR Lens Discussion 20 10-06-2016 05:54 AM
Lens tests on K-1 : 15-30, 24-70, 70-200, 31, 43, 77, 100 Macro, 28-70 and 80-200 Mistral75 Pentax SLR Lens Discussion 14 06-28-2016 11:46 AM
For Sale - Sold: Pentax FA 100-300, FA 70-200, M 28mm; Sigma EX 28-70, Apo 70-300; Tamron Di LD 70-300 stillnk Sold Items 17 04-08-2012 11:39 AM
Wedding zoom? Da16-50/Da16-45/Da17-70/Fa28-70/Sigma17-70??? JayR Pentax SLR Lens Discussion 20 03-18-2010 10:30 AM
All times are GMT -7. The time now is 09:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
