Originally posted by Michael Piziak I just transitioned from the k-r to the k-70. Experiencing a learning curve here.
Questions.
1) I prefer to use the AF-AEL button to cause an automatic lens to focus, which I now have set. However, I don't want the shutter release button to also cause auto focus when pressed half way down. I have AF/AE-L Button set to AF2, but the shutter release button is still causing auto focus also. ?
This is my preference as well. To set it up the way want you need to do the following:
- Go to the menu page Camera 5
- select "Button Customization" from the menu
- select "AF/AE-L Button"
- set it to "AF2 Enable AF2"
This will disable AF with the shutter release button so AF is performed ONLY with the AF/AE-L button.
Originally posted by Michael Piziak 2) On my k-r, I had to select to allow the use of an aperture ring, in the menus, to use manual lenses. Do I need to tell this camera that too? If so, where in the menus?
To enable the use of the aperture ring do the following:
- Go to the menu page C4 (all the way to the right):
- select "Using Aperture Ring"
- set it to "2 (Enable)"
This will enable the use of manual aperture ring.
Originally posted by Michael Piziak 3) On the k-r, I had to program the green button in the menu (to Tv shift I believe). Do I need to program green button in this camera too?
Yes, you should program the green button and set it to Tv Shift. Do that as follows:
- select "E-Dial Programming"
You can customize the E-dial for each exposure mode (Sv, Tv, M, etc)
Note that there are 2 pages of modes; M is on page 2
- to get the preferred settings for M-mode green button, choose the following:
... green-button-TvSHIFT
With this setting, pressing the green button will cause the camera to set the appropriate shutter speed for the aperture you have chosen.
These three things you listed are the first three things that I set when I get a new camera. :-)
I hope this helps,
Dan
---------- Post added 02-19-21 at 06:42 PM ----------
AF/AE-L Button is set to AF2. I think in "auto" mode it still has the shutter release button will autofocus - probably have to be in P mode or other mode to just have af/ae-l button to autofocus, eh?
Yes, the problem is likely that you set it to AF2 for one mode, but not for all of the modes. This is a common problem. To allow for the most customization possible, Pentax lets you use different AF settings in different modes. The downside is that it takes a bit longer to set up all of the modes the way you like.
Dan
