Originally posted by taktoon
Thank You for Your answer. Your solution works on Laowa 100mm (except I cannot set f13 on the lens aperture ring
. The problem with Irix 150 (this lens has a lot more precise focus ring) stays the same - no aperture ring on the lens.
Any other ideas?
And do You know if the situation is the same on KP (as it lacks X mode on the mode wheel)?
Other than the aperture ring, TAv, and X-mode hacks, I know of no other tricks. The KP follows the same general rules as your K-70 as far as I know. Using live view to establish focus for the first frame in a stack along using a focus rail with fixed increment for remainder of the stacking may be an option.
