04-10-2021, 03:57 PM - 6 Likes   #1
jon.partsch's Avatar
Super cheap K-70 from Amazon Warehouse
A member recently highlighted a deal on a used "acceptable" condition K-70 on Amazon from Amazon Warehouse Deals:
Pentax K-70 Body In Amazon Warehouse $234.84 - PentaxForums.com
I snapped it up and just received it today. It looks absolutely brand new except for not including the original box. I cannot find a mark or cosmetic flaw of any kind on it whatsoever, despite the listing indicating:
"1 of: Pentax K-70 Weather-Sealed DSLR Camera, Body Only (Black)
Sold by: amazon.com Services LLC
Condition: Used - Acceptable
Cosmetic imperfections, bigger than 1", on front of the camera body. Item will come repackaged."
Here is a photo of what I received from Amazon Warehouse:
I will update this post/thread with the results of my testing, which I expect to complete this coming week.
04-10-2021, 04:10 PM   #2
ChristianRock's Avatar
Congrats, that was a really nice grab!! Post some pictures from it when you can!
04-10-2021, 04:38 PM   #3
jumbleview's Avatar
Nice catch. Just to satisfy my curiosity, did you check shutter count?
04-10-2021, 08:52 PM   #4
Nice score!
04-11-2021, 11:34 AM - 2 Likes   #5
So, Here are some more details of brief testing.
I am pretty certain that none of the items in this kit had previously been removed from their plastic baggies or bubble wrap. If they had, someone was very careful to repackage everything without evidence that it had been opened. The battery is stamped with a manufacturing date of March 2020 (202003).
The battery's initial voltage when removed from packaging was 7.37 volts on my multimeter, indicating roughly 50% charge, which is what one would expect for a battery shipped from the factory.
As you can see from the photos below, there was plastic film over the rear screen, and the camera powered up to set-up mode (firmware version 1.0). I went through the setup process (some settings, like date format, were already modified by me before snapping these photos) and snapped a photo last night. I have included both this photo, and EXIF metadata analysis from the online tool here on PentaxFoums ( Check Camera Shutter Count and Manufacture Date ). I am including the metadata analysis in a separate table for convenience. The first photo I took (IMGP00001.JPG) shows a shutter count of "2" which, if accurate, may reflect a single snap previously performed at the factory as part of QC procedures. EXIF shows a manufacture date for the camera body of August 20th, 2020, so very recent for a camera model released in, I think, 2015.
QuoteOriginally posted by jumbleview Quote
See below!
QuoteOriginally posted by ChristianRock Quote
You can count on it. I hope to post some photos later this week, but I see no reason to suspect an issue with the aperture block/solenoid given the camera's recent manufacture date. I have, however, picked up one of the older "white, made-in-Japan" solenoids to be on the safe side, in case problems develop later on.
Here is the first photo I took with the camera (entertaining these ladies last night with veggie burgers and teriyaki chicken on the grill). Metadata also in separate tables below:
Results
Your photo's metadata indicates the following:
CameraPENTAX K-70
Shutter Count2
Manufacture Date2020:08:20
LensTamron AF 17-50mm F2.8 XR Di-II LD (Model A16)
Full EXIF Data
Below is the full metadata from your photo:
AELockOff
AEMeteringSegments11.5 11.1 10.8 10.2 10.2 10.2 10.2 10.2 10.6 11.4 12.0 9.5 9.1 8.9 8.6 8.6 8.5 8.6 8.6 9.1 9.4 9.8 9.4 8.9 8.9 8.5 8.4 8.2 8.5 8.4 9.0 9.2 9.5 9.6 9.2 8.9 8.5 8.5 8.5 8.6 8.8 9.1 9.4 10.0 10.1 9.6 9.2 9.1 9.0 9.1 9.0 9.2 9.8 9.9 10.5 10.6 10.4 10.1 9.8 9.6 9.6 9.6 9.9 10.2 10.6 11.0 11.8 11.1 11.0 10.8 10.5 10.6 10.6 10.9 11.0 11.5 11.9
AFAdjustment0
AFDefocus1
AFIntegrationTime0 ms
AFPointSelectedFace Detect AF; 0
AFPointsInFocusNone
AFPredictor0
Aperture4
Artist
AspectRatio3:2
AutoApertureOn
AutoBracketing0 EV, No Extended Bracket
BitsPerSample8
BlackPoint64 64 64 64
BleachBypassToningn/a
BodyBatteryStateFull
BodyBatteryVoltage17.87 V
BodyBatteryVoltage27.49 V
CameraTemperature26 C
ChromaticAberrationCorrectionOff
CircleOfConfusion0.020 mm
ClarityControlOff
ColorComponents3
ColorSpacesRGB
ComponentsConfigurationY, Cb, Cr, -
CompositionAdjustOff
CompositionAdjustRotation27
CompositionAdjustX108
CompositionAdjustY1
CompressionJPEG (old-style)
ContrastHigh
ContrastDetectAFArea160 132 400 216
ContrastHighlight0
ContrastHighlightShadowAdjOff
ContrastShadow0
Copyright
CreateDate2021:05:10 18:01:37
CrossProcessOff
CustomRenderedNormal
DSPFirmwareVersion1.00.01.05
DataScaling8159
Date2021:05:10
DateTimeOriginal2021:05:10 18:01:37
DestinationCitySan Francisco
DestinationDSTYes
DiffractionCorrectionOff
DistortionCorrectionOff
DriveModeSingle-frame; No Timer; Shutter Button; Single Exposure
DynamicRangeExpansionOn; Auto; 0; 0
EVSteps1/3 EV Steps
EffectiveLV7.5
EncodingProcessBaseline DCT, Huffman coding
ExifByteOrderLittle-endian (Intel, II)
ExifImageHeight4000
ExifImageWidth6000
ExifVersion0230
ExposureCompensation0
ExposureModeAuto
ExposureProgramAperture-priority AE
ExposureTime1/80
ExtenderStatusNot attached
FNumber4
FOV40.3 deg
Face1Position594 181
Face1Size42 41
Face2Position114 154
Face2Size45 45
FaceDetectOn (16 faces max); 2 faces detected; 2
FaceDetectFrameSize720 480
FacePosition82 37
FacesDetected2
FileSize13 MB
FileSourceDigital Camera
FileTypeJPEG
FileTypeExtensionjpg
FineSharpnessOff; Normal
FlashOff, Did not fire
FlashExposureComp0; 0
FlashMeteringSegments0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
FlashModeOff, Did not fire; Internal
FlashpixVersion0100
FocalLength32.5 mm
FocalLength35efl32.5 mm (35 mm equivalent: 49.0 mm)
FocalLengthIn35mmFormat49 mm
FocusModeContrast-detect (Focus-priority)
FocusRangeIndex4
GPSVersionID2.3.0.0
HDROff; Auto-align Off; n/a; 0
HighISONoiseReductionAuto; Inactive
HighLowKeyAdj0
HometownCitySan Francisco
HometownDSTYes
HueNormal
HyperfocalDistance13.25 m
ISO800
ImageEditCount0
ImageEditingNone
ImageHeight4000
ImageSize6000x4000
ImageToneBright
ImageWidth6000
InternalSerialNumber2027696
InteropIndexR98 - DCF basic file (sRGB)
InteropVersion0100
IntervalShootingOff
KelvinWB_012500 0 1.1820068359375 2.9888916015625
KelvinWB_022630 0 1.24462890625 2.80810546875
KelvinWB_032780 0 1.3282470703125 2.643310546875
KelvinWB_042940 0 1.410888671875 2.497314453125
KelvinWB_053130 0 1.4990234375 2.35107421875
KelvinWB_063330 0 1.5863037109375 2.2210693359375
KelvinWB_073570 0 1.6888427734375 2.091064453125
KelvinWB_083850 0 1.806640625 1.9669189453125
KelvinWB_094170 0 1.9346923828125 1.85205078125
KelvinWB_104550 0 2.0699462890625 1.740966796875
KelvinWB_115000 0 2.20166015625 1.633544921875
KelvinWB_125560 0 2.3258056640625 1.5242919921875
KelvinWB_136250 0 2.4364013671875 1.4176025390625
KelvinWB_147140 0 2.5458984375 1.3175048828125
KelvinWB_158330 0 2.685791015625 1.2371826171875
KelvinWB_1610000 0 2.9200439453125 1.2027587890625
KelvinWB_Daylight5205 0 2.2506103515625 1.5916748046875
LensFStops8.5
LensFocalLength32.5 mm
LensIDTamron AF 17-50mm F2.8 XR Di-II LD (Model A16)
LensTypeTamron AF 17-50mm F2.8 XR Di-II LD (Model A16)
LevelOrientationHorizontal (normal)
LightValue7.3
MIMETypeimage/jpeg
MakeRICOH IMAGING COMPANY, LTD.
ManufactureDate2020:08:20
MaxAperture2.8
Megapixels24
MeteringModeMulti-segment
MinAperture22
MinFocusDistance0.25-0.28 m
ModelPENTAX K-70
ModifyDate2021:05:10 18:01:37
MonochromeFilterEffectNone
MonochromeToningNone
NoiseReductionOff
NominalMaxAperture2.8
NominalMinAperture32
NumAFPoints11
PentaxModelIDK-70
PentaxModelType0
PentaxVersion12.1.3.0
PeripheralIlluminationCorrOff
PictureModeAperture Priority; 1/3 EV steps
PitchAngle-13.5
PixelShiftResolutionOff
PowerSourceBody Battery
PreviewImage(Binary data 55522 bytes, use -b option to extract)
PreviewImageBorders0 0 0 0
PreviewImageLength55522
PreviewImageSize720x480
PreviewImageStart39396
PrintIMVersion0300
ProductionCode2.1
QualityBest
RawDevelopmentProcess17 (K-70)
ResolutionUnitinches
RollAngle1
SaturationNormal
ScaleFactor35efl1.5
SceneCaptureTypeStandard
SceneTypeDirectly photographed
SensingMethodOne-chip color area
SensitivityAdjust0
SensitivitySteps1 EV Steps
SensitivityTypeStandard Output Sensitivity
SerialNumber
ShadowCorrectionAuto
ShakeReductionOn (AA simulation off)
SharpnessHard
ShutterCount2
ShutterSpeed1/80
SkinToneCorrectionOff
SlaveFlashMeteringSegments0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
SoftwarePENTAX K-70 Ver. 1.00
SourceDirectoryIndex0
SourceFileIndex0
StandardOutputSensitivity800
SubjectDistanceRangeClose
ThumbnailImage(Binary data 7159 bytes, use -b option to extract)
ThumbnailLength7159
ThumbnailOffset32138
Time18:01:37
TungstenAWBStrong Correction
WBShiftAB0
WBShiftGM0
WhiteBalanceAuto
WhiteBalanceAutoAdjustmentOff
WhitePoint22400 8192 8192 11392
WorldTimeLocationHometown
XResolution300
YCbCrPositioningCo-sited
YCbCrSubSamplingYCbCr4:2:2 (2 1)
YResolution300
---------- Post added 04-11-2021 at 11:40 AM ----------
.....In conclusion, it seems that this is a factory new camera that simply lacks it's orginal box, and as I also noticed, its printed instruction manual.
I also just noticed that I accidentally set the month ahead by one when I was setting up the date. I corrected this.
~ Jon
04-12-2021, 10:56 AM   #6
QuoteOriginally posted by jon.partsch Quote
As you can see from the photos below, there was plastic film over the rear screen, and the camera powered up to set-up mode (firmware version 1.0). I went through the setup process (some settings, like date format, were already modified by me before snapping these photos) and snapped a photo last night. I have included both this photo, and EXIF metadata analysis from the online tool here on PentaxFoums ( Check Camera Shutter Count and Manufacture Date ). I am including the metadata analysis in a separate table for convenience. The first photo I took (IMGP00001.JPG) shows a shutter count of "2" which, if accurate, may reflect a single snap previously performed at the factory as part of QC procedures. EXIF shows a manufacture date for the camera body of August 20th, 2020...
~ Jon
I've had that happen more than once with an Amazon Warehouse buy, brand new and never unpacked stuff that was marked in the description as having a blemish. An example would be my 27" 4K monitor listed with blemishes on the frame, but on receipt there were none, never removed from the plastic which was still taped to the monitor. I consider Amazon Warehouse deals to be a pretty solid gamble.
Always good to see forum members get a deal on their gear.
04-12-2021, 11:25 AM   #7
QuoteOriginally posted by gatorguy Quote
Amazon Warehouse is almost always worth the gamble for me as someone in a relatively urban/suburban environment because, even if the item is exactly as described and I simply decide that I don't want it, there are plenty of Amazon drop-off sites (like Whole Foods) where I can return it for free for simply having "changed my mind"
I am thrilled to have gotten amazing deals on almost all of my Pentax DSLRs over the years:
  • My K110D had less than 200 shutter actuations when I got it on eBay for $150 when the model had only been on the market a couple of years
  • My K-5 was the only body I paid full retail - about $1000
  • My K-1ii had less than 2000 shutter actuations when I got it in like new condition as part of a large package of FF lenses and equipment from a fellow forum member. It's hard to estimate my cost on this one, as it was part of a package, but I am estimating about $1200
  • Now I got a brand new K-70 $255 after factoring in the sales tax.
I will be listing my K-5 in the sales section very soon.
04-12-2021, 04:57 PM   #8
jumbleview's Avatar
From my experience it will work for you for first your return, maybe for second. But then you'll start to see problems.
04-12-2021, 05:14 PM   #9
Ah! good to know. I've probably only ever returned a couple things to Amazon Warehouse.
04-13-2021, 06:27 AM   #10
Wow, it looks like you got a really good deal. From my purchase of a new K-70 previously, I don't remember it having the plastic film over the LCD but perhaps Ricoh updated the packaging. Anyway, glad to hear that it worked out for you.
04-13-2021, 09:06 PM   #11
Yes! I'm thrilled this one is in great condition and working without the solenoid failure!
You got a steal with this one!
And echoing so many other comments elsewhere... i can't even begin to tell you how many great snags I've picked up off Amazon Warehouse.
04-14-2021, 01:31 PM   #12
QuoteOriginally posted by disasterfilm Quote
I have also purchased a group of four "parts" bodies including three K100-series and one *ist-series body. I will be harvesting the "made in Japan white" solenoids from them, keeping one for myself (just in case) and offering the rest to the community here at a cost that merely covers the cost of the parts bodies and shipping. They will probably be about $25 each as opposed to the one seller on eBay who is offering Japan/white solenoids for $45 each. I hope this will be a help to some other folks. Incedentally, I will have some other bits from those bodies I can send along to folks that need them for a couple $US.
QuoteOriginally posted by reduno Quote
I was able to find three unboxing videos for the K-70 where there was no cut-away in the video from when the box was first opened to when the rear screen was first folded out. I think only one of these videos showed a buyer/unboxer in the USA, but none of the three cameras in those videos had this film on over the screen. I doubt this means anything, because who would go to the trouble of doing something like this to make a used camera appear new, especially if it wasn't consistent with the original packaging?
04-18-2021, 06:40 PM   #13
It looks like your listing for the solenoids is now live. Thanks for offering these to users who don't want the trouble of acquiring and dismantling a donor camera.
I suspect most of the unboxing videos were taken shortly after the K-70 was introduced. It's quite possible Ricoh updated the camera packaging, to add the protective film at some point in the production run.
04-18-2021, 07:52 PM   #14
Thank you!! If these sell quickly, then I will try to offer more if I can find any more cheap parts bodies.
Yeah, totally. Whatever the reason for the film on the back screen, it amounts to nothing.
- Jon
04-23-2021, 07:37 PM - 2 Likes   #15
Well, I'm afraid I couldn't resist when Amazon posted another K-70 with the same price and condition description. I already have a K-70 stuck in the UK that I can't get to due to Covid-19 travel restrictions, so I guess I will really need another one anyway. I will let you know how it looks when it turns up.
amazon, amazon warehouse deals, auto, body, camera, condition, date, k-70, k-70 from amazon, k70, metadata, mm, model, none, pentax, pentax k-70, photo, shutter, warehouse
HD Pentax FA 35mm F2.0 Amazon Warehouse $207.53 reduno Pentax Price Watch 20 3 Days Ago 05:09 PM
Used D FA 150-450mm f4.5-5.6ED @ Amazon Warehouse - $1472 luftfluss Pentax Price Watch 6 04-26-2021 11:08 AM
Pentax K-70 Body In Amazon Warehouse $234.84 reduno Pentax Price Watch 9 04-10-2021 04:01 PM
Used DFA 150-450 @ Amazon Warehouse - $1214 luftfluss Pentax Price Watch 36 12-21-2019 10:01 PM
Pentax D FA 150-450 used on Amazon Warehouse Deals dave2k Pentax Price Watch 5 11-04-2017 02:21 PM
All times are GMT -7. The time now is 05:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
