Originally posted by Not a Number Do you have another lens to test it with? In particular a non-screw drive lens or screw drive if the lens is non-screwdrive AF.
What lens are we talking about here?
Since you were buying the lens presumably you have another body. How does the lens work on another body?
Thank you for the comments, the lens works fine on my K-1, unfortunately all i have is FA screw drive lenses!
kypfer - yes the little focus confirmation worked in manual focus
photooptimist - a factory reset is what i first tried (just through settings option) HOWEVER , thank you for the suggestion to downgrade, and then re-update the firmware. I didn't know you could downgrade, that's fantastic. this has indeed fixed the focus issue! now it's snappy and locks on as it should. and autofocus now works in live view!
unfortunately..... i must have spoken too soon (and not done sufficient testing) to check for the aperture block issue, because this is also present. cycling a few times in and out of live view seems to do the trick for now, but i think i will need to test my skills and do a repair. time to start searching the forums for info on the best solenoid to buy!
thank you again everyone for your quick suggestions! This mystery is officially solved.
